cool DIY infinite LED tunnel by curly B.
Featured
Step 3: Led strip
now build a led strip on the inner side of the square as shown in the picture(be sure to add also resistors as shown below)
than glue all together
jimmyt9574 says: Feb 21, 2011. 1:48 PM
Where did you get your LEDs from? Did you buy online or at a local place?
BOOJAN says: Nov 4, 2010. 5:03 AM
here is one online calculator that will help you for choosing the right resistor (not the right girl :P)...
http://www.hebeiltd.com.cn/?p=zz.led.resistor.calculator
bloodhunterz says: Oct 20, 2009. 9:38 PM
what resistor did you use and is the copper wire connected at the end.
curly B. (author) says: Oct 23, 2009. 12:15 PM
hi,i've used the resistors that usually comes with the leds...now i don't have those resistors so i can't tell you the exact value ..i'm sorry.....but you can easilly calculate the right size of the resistors by using a simple formula R=V/I where V stands for the voltage(Volt) and I stand for the current(Ampere), you can find those values in the led specifics...good luck:-)
bloodhunterz says: Oct 23, 2009. 3:55 PM
thank you for info!!! and tacking time to answer me.
curly B. (author) says: Oct 23, 2009. 4:21 PM
you're welcome...i just want to apologize for the delay of my reply....
bloodhunterz says: Oct 23, 2009. 5:09 PM
no problem.
Graveyard_Disciple says: Oct 15, 2009. 7:24 PM
what size resistor did you use
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
