*WARNING! WARNING* DANGER WILL ROBINSON!
Yes, there are tools used in this instructible. Yes, there is sharp metal in this in structible. YES, use extreme caution when working with tools or metal of any kind, you CAN injure yourself.
Ok, with THAT out of the way...
Remove these ads by
Signing UpStep 1Measure and cut copper tube
If you don't have a fabric tape measure, you can wrap a piece of string round your wrist, and measure that. This is the length of tube you need to cut for your cuff. Mine was a bit more than 8". A hacksaw works well to cut the tube. If you have a tube cutter, I would recommend that for this step. It makes later steps much easier. I couldn't find a hacksaw or a tube cutter (though I own BOTH) so I used an angle grinder to cut it. The diameter of the tube will determine the width of the cuff. If you look above the vise, there is a LARGE copper cuff from a 2" tube in progress.
I honestly do not like copper or brass jewery because of the discoloration...but if you coat the inside withsome sort of protective barrier then you dont get the discoloration
...i typed that whole thing to the beat of the song that I am listening to...
Lulz.... I am constantly listening to music... and yep, I have (often) type to the beat of whatever I'm listening to....
(I'm doing so now.... >
http://www.sciencedirect.com/science/article/pii/S1389172311003446
With regard to copper, be in contact with copper very long time do not think is very good. There are people who suffered from copper poisoning (in water and food).
But copper should help prevent the accumulation and bacteria reproducicon of some common diseases.
(sorry for my english, i use google translate)
what do you use to laquer it?
Copper and it's green derivates is mostly poisonous by ingestion not by contact on skin but stains it like silver and is a considerable water environment hazard agent.
Copper rules! Excellent Ductility and Conduction!
Check out the link:
http://en.wikipedia.org/wiki/Calcolithic
