loading
Step 5: Bend Copper to Shape
Get a large diameter piece of steel or iron tube for your mandrel.  Using the soft faced hammer, start to bend the very edge of the bracelet.  Use sharp overlapping strikes along the width of the copper to start the copper curving.  It will look much smoother when you are completed.  Once the copper has a bit of curve, take the metal in hand and manually put a sharper curve in the metal simply by carefully bending it.  This is a great deal quicker and much easier.  From there put the curved copper (now very MUCH like a cuff) on the mandrel and hammer smooth and symmetrical any parts of the bracelet that look out of place until it all looks right.  Or at least, right enough to you.
<p>i have made a cuff like that before, but i didn't cut the tube, i just pounded it flat on the anvil and then bent it to shape. no sharp edges, just square sides that i had to sand smooth</p>
<p>I have used Johnson's Paste Wax from the hardware store to protect metal, brass, steel, copper from oxidizing without any trouble, if you do the inside and edges with it ever so often it won't cause your wrist, finger etc to turn green.</p>
I wear a brass anklet all the time - it's made from an old ceiling fan pull chain... and I have yet to suffer any ill effects.. though if I sweat a lot I will have a bit of a greenish discoloration form the copper on my skin - but that just washes off. Anyways I think this is a neat instructable... on a side note you could get nice copper sheets from this method... and if you are like me and strapped for cash and love steampunk... this is a perfect solution! (Now only if I could find some brass pipe to do this to... )
STEAMPUNK!!!!!!!!!!!!!!!!! <br> <br>I honestly do not like copper or brass jewery because of the discoloration...but if you coat the inside withsome sort of protective barrier then you dont get the discoloration <br> <br>...i typed that whole thing to the beat of the song that I am listening to...
Whenever you take your jewellery off if you give it a wipe with a soft cloth to remove grease/ sweat etc store it in little bag out of the air and you shouldn't have a problem. You can buy jewellery wax although this is very expensive, I like to use a small amount of liquid car wax to give it a protective coating, keeps the bright colour and also prevents the 'green' colour transfer. I re-coat as necessary (prob every 6mnth or so). <br>
^.^! <br>Lulz.... I am constantly listening to music... and yep, I have (often) type to the beat of whatever I'm listening to....<br> (I'm doing so now.... &gt;
One of my hobbies is to listen to Podcasts from German radio stations. A Podcast I recently heard spoke about the germ killing properties of copper. Until recently people in many cultures were available that people in contact with copper were sick less often. You can hear a National Public Radio broadcast about recent studies of copper as a germ killer at <a href="http://www.npr.org/templates/story/story.php?storyId=99458486">this link</a>.
i heard the same thing about copper. The silver have similar propierties, but it's more expensive.
I was doing two things at once when I posted. I meant to say, &quot;Until recently people in many cultures were <em>aware</em> that people in contact with copper were sick less often.&quot; Another helpful germ killer is eating any food high in poly-phenols. Grapes and things like wine fall into this category. For poly-phenols to be effective, there needs to be an acidic environment. I think your stomach would suffice for that. I saw something about silver ions killing germs. When I was quite young my mother would bring home silver iodide sticks from the hospital where she worked and we would use them to touch canker sores in our mouths. The silver iodide sticks made my canker sores heal up quickly. My wife tried it years later, but it did not work for her. A silver iodide stick is a wooden stick, like a fireplace starter stick or a piece of wood from a potsticker meat serving, like a wooden skewer. One end looks burned from being soaked in silver iodide. I expect it turned dark from exposure to light. Silver iodides were used in photographic film, too.
I think the silver iodide is also used to purify water in emergency situations. <br>With regard to copper, be in contact with copper very long time do not think is very good. There are people who suffered from copper poisoning (in water and food). <br>But copper should help prevent the accumulation and bacteria reproducicon of some common diseases.<br>(sorry for my english, i use google translate)
Generally speaking, prolonged exposure to copper does not cause health problems. But I do lacquer the inside of the bracelets, not so much for the copper, but to keep from turning green as quickly!
mi bracalets turn dark brown inside very quickly, yours turn green? maybe because is another copper aloy.<br>what do you use to laquer it?
His arm turns green.
Nails laquer, better a most neutral color. Clean and dry well before. There's also some specific product used by goldsmiths to isolate allergenic nickel sometimes present in tiny steel springs in ear rings for rust protection but I think it's not so easy to find and at the moment I don't remember the name of it . Anyway I would try to put some transparent plastic spoons ore the like in acetone for one night in a tight closed PVC or glass bottle and trimm the acetone to obtain a not so thick non so liquid stuff and see how it drips after dipping the copper thing in. I'm going to try a similar stuff to repair a crack in my car's back ligths dissolving , and it does, the red plastic in acetone . <br>Copper and it's green derivates is mostly poisonous by ingestion not by contact on skin but stains it like silver and is a considerable water environment hazard agent.
New study that found copper antibaterial for multiple drug resistant bacteria (only abstract and some figures are availible for free viewing). See link: <br>http://www.sciencedirect.com/science/article/pii/S1389172311003446
Master Beorn, revive the Calcolithic Era! <br>Copper rules! Excellent Ductility and Conduction! <br>Check out the link: <br>http://en.wikipedia.org/wiki/Calcolithic
Copper, silver and gold all have antibacterial properties. Interesting side note... gold and silver are two of the three elemental metals that are not silver or gray in color. The other is caesium, BTW... I think copper is SO underused as a jewelry metal in our society. In many others, it is used widely, due to the relative ease of smelting and high malleability. I may post some more here soon! Thanks for the comments!
OOps, I meant COPPER, not SILVER. Sorry.
great work, i have made very similar bracalets time ago.
About This Instructable
36,447views
110favorites
License:
Bio: I make stuff. All sorts of stuff. I prefer to use materials that would otherwise be headed for the landfill. It's the best seeing ... More »
More by Master Beorn:Glass Cabochons for Jewelry Pottery "jewel" Cabochon One jar of pickles at a time!
Add instructable to:
