3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
cube lube
cube lube
in this wonderfull instructable i will teach you to lube a rubik's cube.
Step 1Gather supplies
gather supplies
for this instructable you will need:
1 rubik's cube in need of a lube
1 drinking straw (not the big kind) the bend doesn't matter.
some petroleum jelly
a towel (optional) if you dont use it your rubiks cube will be slicker than snot.
156 comments
1-40 of 156next »
Nov 10, 2011. 2:03 PMmajorson says:
Nice instructable, although I really DOESN'T recommend using Petroleum jelly on the Rubik's Cube, because it makes the Cube really sticky after it!!
Here some Rubik's Cube tips - great for improving your solving time!.
Nov 25, 2007. 5:13 PMbigg1101 says:
i solved the cube in 1 minute and 14 seconds
Dec 12, 2007. 5:32 PMthe_burrito_master says:
with a guide
Jan 6, 2012. 5:43 PMtechnologicalterror says:
Do you know how to solve one, if not, go to you tube and type in "how to solve a rubiks cube part 1"
Jan 7, 2012. 5:56 AMthe_burrito_master says:
that was back before i memorized all the algs I now can do it no sweat. i also solve the 5x5x5 and I have a megaminix
wow takes me 10 mins
Nov 4, 2008. 12:37 PMrippinblaise says:
takes me about 3 minutes, but i just memorized the algorithms yesterday and i looked up the video the day before....so im a pretty new cuber
Jan 6, 2012. 5:40 PMtechnologicalterror says:
Do you possibly now the algorithm ri,di,r,d?
Jan 23, 2010. 11:42 AMaphroditedarius says:
hey i tried it and it made my cube mor stiff :( i just did it a couple minites ago.  will it loosen up over time?
Feb 28, 2010. 7:12 PMbassclarinet23 says:
Just so you know, Petroleum Jelly contains petroleum. When petroleum and plastic, let's say from a Rubik's cube, the petroleum erodes the plastic...eats away at it, if you will. ;)
Jan 6, 2012. 5:36 PMtechnologicalterror says:
I had mine after it was lubricated for about a month and nothing happend.
Jun 6, 2011. 2:44 AMmosted1 says:
Yeah, so its a good thing to put in a stiff cube for a day or 2 so it become looser, and then clear out the jelly next you could use silicon lubricant to really lubricate it.
Jan 6, 2012. 5:34 PMtechnologicalterror says:
I'm just a beginner but I was able to solve in 1.33:447, please reply if you like my time.
Feb 27, 2009. 2:21 PMsk8master says:
takes me about 3 mins but i just learned this week and thats without lube
Mar 1, 2009. 7:30 AMsk8master says:
now i can solve th cube in 2 mins and 20 seconds
May 2, 2011. 7:36 AMThe Scarlet Tomato says:
2 minutes, 16 seconds
Sep 28, 2011. 2:51 PMThe Scarlet Tomato says:
New time. 56 seconds.
Nov 24, 2011. 5:47 PMstimky666 says:
44seconds is my top doing the Beginners Method. 12.4 is my top doing Fridrich.
Apr 16, 2009. 12:50 PMdustin_virva says:
i need yalls help i just got a rubix cube iv tryed reading how to do it its all so confuseing could some 1 like go step by step with me?
Feb 28, 2010. 7:14 PMbassclarinet23 says:
Go to YouTube and look up "Rubik's Cube Part 1". It is the sole reason I can solve the thing.
Jul 16, 2011. 3:35 PMTigrisLi says:
I just take a cotton swab and put some water and soap and it works pretty good
Jun 16, 2011. 3:19 PMThe Scarlet Tomato says:
DO NOT USE PETROLEUM JELLY.
May 12, 2011. 1:21 AMjwoo2023 says:
i cant understand step 4
May 12, 2011. 1:17 AMjwoo2023 says:
use vaseline!
May 25, 2010. 3:49 AMZeroError says:
Petroleum jelly can harm your cube - the best kind, in my opinion, is silicon lube. It stays working for ages.
May 2, 2011. 7:32 AMThe Scarlet Tomato says:
Yes, definitely use silicone spray.
Jul 18, 2010. 10:22 PMPilgrimm says:
There is a product called "Slipit" which is inexpensive, nontoxic, and washes away with surface cleaners, soap, etc. You should be able to find it in any Lowe's or Home Depot store. Petroleum jelly will work great, but over time will attack the plastic, and the cube will get "sticky." Silicone will work well too, except that silicone is going to "contaminate" your environment. Silicone is great stuff, but it never goes away. It can make your floors slippery, it gets into cd drives, dvd players, etc, and is almost impossible to remove, and can be toxic if ingested!
Jul 19, 2010. 6:21 PMThe Knex Builder says:
Whatever you do , don't use petroleum jelly. It melts the plastic, peels the stickers, and makes it disgusting. I would use Jig a loo or silicone spray but don't over lube it or you cube will be bad.
Feb 27, 2011. 6:41 PMThe Nomlack says:
Jig a loo is the best in the world
Dec 25, 2010. 9:05 AMSorunome says:
42 seconds!!
Feb 26, 2011. 3:51 PMThe Nomlack says:
15 secs!
Feb 27, 2011. 3:21 AMSorunome says:
damn!
Aug 14, 2010. 6:17 PMJustModIt says:
if petroleum jelly "eats" plastic, than why is it packaged in plastic containers? or is the container something else?
Jul 9, 2010. 12:36 AMlubixcube says:
you should try using lubix, it works much better. http://www.lubixcube.com
Jun 1, 2010. 3:30 PMjoetheninja says:
45 seconds best, 1 minute average
Apr 25, 2010. 8:04 AMtrgz says:
(just posted this elsewhere)
I used to use talc when they first came out in the early 80's - only ever made managed a 1min14 sec but it was nicer to your hands than most other lubes!
Feb 18, 2010. 1:15 PMAJBrawlLvr says:
 just did this w/ my cube that once, when I got annoyed, I hit with a sledgehammer. :) It works like (almost) new!
5*
Dec 28, 2009. 11:10 AMChromeEagle says:
Takes me 38.57 secs , used to be 5 seconds more until this, ty man
Jul 14, 2009. 9:14 PMScotish says:
My best time is 48 seconds and I use a beginner Method that uses the layer Theory to solve it and has around 7 algorithms that aren't to long. If anyone wants me to do an Instructable on it feel free to ask and I will gladly do it.
Dec 17, 2009. 6:35 AMakinich says:
hey thanks for the offer
can you please do an instructable on your layer concept
i have a hard time learning how to solove a rubix cube
thanks
akinich
1-40 of 156next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:fredricksburgthethird
i like instructables,ductape ipod,and other stuff.
