custom Kirby usb flash drive
I had a flash drive with a broken plastic case, so rather than tossing out the innards, I decided to use some Sculpey clay and make a new body for it.
I used "Sculpey III" clay, numbers 503 (Hot Pink), 303 (Dusty Rose), 001 (white), and 042 (black). I also used a broken PNY Attache flash drive. (You can use any flash drive you may have lying around)
Step 1Clay time...
Clay time...
For this step, I took a strip (there are four strips per block) of both the hot pink clay and of the dusty rose. I then split both strips in half. With both sets of two, I mixed the hot pink and dusty rose together to make the solid pink on the main picture.
I pushed each mixture into a 5x5 inch circle, and placed the flash drive into one of them. On the other circle, I made small ovals with the black clay for the eyes, followed by small white dots at the top of each eye. For the mouth and cheeks, I took a tiny bit of the hot pink clay to make two ovals for the cheeks, and a half circle for the mouth.
You can now place the top circle on the one with the flash drive in it. (make sure there is no air between the two circles, as the bubbles will be there after you bake it.) Now use your finger to smooth the edges together.
13 comments
Feb 2, 2009. 3:28 AMcokecola says:
I had been wondering if a USB would withstand the heat of an oven but didn't want to take a chance to find out. Thanks for the info.
Nov 7, 2008. 3:08 PMYokenn says:
This is great! Now my sister's USB will not be "naked" anymore. Thanks!
Oct 25, 2008. 2:05 PMwatermelonhead says:
wouldn't something happen to the usb?
Jul 1, 2008. 9:48 AMbounty1012 says:
poor kirby with his head stuck in a computer AND HE STILL SMILES... lol nice instructable and it propably gets a little scary at times when you look at him and hes still smiling!
Jun 8, 2008. 5:08 PMcasper.707 says:
Kirby rules!
Apr 17, 2008. 6:56 PMthe_burrito_master says:
burninnation! pore Kirby lol.
Feb 19, 2008. 7:45 PMjoey2542667 says:
Ummm... wouldn't the USB stick malfunction from the clay and especially the heat from the oven? P.S.-- just a little idea, make something that would be cool when the light flashes(for example; make a one-eyed goblin with the light on the eye!)
Feb 15, 2008. 5:47 PMGorillazMiko says:
If you were to make like a figure, would it melt? For example, let's say there was a ball. I put it to bake, would it start to mush down and melt, or would it bake the way it was? Not really a ball.. just an example. Thanks!
Jan 23, 2008. 3:59 PMGorillazMiko says:
Cool! I might do this, this is awesome, it's easy too! Nice job! (added to favorites)
Jan 23, 2008. 12:49 PMiTHROWDOWN says:
now i have the green greens theme in my head good job on this man
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:buckyboy28
