I used "Sculpey III" clay, numbers 503 (Hot Pink), 303 (Dusty Rose), 001 (white), and 042 (black). I also used a broken PNY Attache flash drive. (You can use any flash drive you may have lying around)
Remove these ads by
Signing UpStep 1Clay time...
I pushed each mixture into a 5x5 inch circle, and placed the flash drive into one of them. On the other circle, I made small ovals with the black clay for the eyes, followed by small white dots at the top of each eye. For the mouth and cheeks, I took a tiny bit of the hot pink clay to make two ovals for the cheeks, and a half circle for the mouth.
You can now place the top circle on the one with the flash drive in it. (make sure there is no air between the two circles, as the bubbles will be there after you bake it.) Now use your finger to smooth the edges together.
13
comments
Add Comment
Add Comment
