Here is how to make fitted gel insole made just for your unique feet, for about 20 bucks. fitted orthotics are about 300 bucks
Materials
1 pair of your socks
2 tubes silicone caulking (a pack of 3 tubes was 10 bucks from a hardware store, you may need more is your feet are bigger then mine. I'm a size 9.5 mens)
1 small bottle of glycerine (5 bucks from a pharmacy, this will do about 3 or 4 pairs)
caulking gun (5 bucks from a hardware store)
a cardboard box
1 old spatula or paint stir stick
your hands and feet will get a little bit sticky
note the caulking will smell strong like vinegar but it should be non-toxic, if the smell bothers you, move to a better ventilated area
Remove these ads by
Signing UpStep 1Silicone caulking set up
squirt out all the silicone caulking from one tube on to a piece of cardboard. one tube will do one insole. If you feet are bigger than a mens 9.5 you might need to add another half a tube.
2nd step.
add about 5 drops of glycerine for every ounce of caulking (if you dont add the glycerine the silicone will not cure all the way through and you will have a cured surface but a uncured middle) and mix thoroughly with spatula.
note
the warmer your work space the quicker the cure time but you should have about a 20 min window before its starts to cure.
And now you gave me a good idea. put a piece of plastic wrap on the top so your feet will not get sticky, when you make them, then just peel the plastic off.
Another thing you can do to stop it sticking to hands or feet is use vaseline (petroleum jelly) on them. Just rub it into your skin and the silicone shouldn't stick.
Ever since I saw the "Ogoo" caulking Sugru substitute
(http://www.instructables.com/id/How-To-Make-Your-Own-Sugru-Substitute)
I've had a similar-type of project in mind. The one thing I'm not sure about is that some people say Silicone is acidic and can burn your skin. Did you experience any of that when you did this?
Thanks, and again, this idea ROCKS!
No I didn't get any burns or discomfort at all, lol but i did have sticky hands and feet lol.
that Ogoo sounds intriguing. I wonder how soft the final product will be?
