3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
dgms blazer sniper in pistol form
MY FIRST INSTRUCTABLE =)
PROS
true trigger
use only a small amount of pieces
powerful
comfy (kinda)
CONS
1/6 in accurate
credit for dgm for the mecanisim guard trigger and almost everything else but the pistol form
have fun building!!!!!!!!!!!!
rate rate rate rate rate rate rate rate rate rateate rate rate rate raterate rate rate rate rate
rate rate rate rate raterate rate rate rate rate
rate rate
Step 1Body
body
1. make 2
2.add rods on 1 of the sides
29 comments
Apr 19, 2010. 4:55 AMjames4 says:
YYY............YYY..........EEEEEEEEEEEE..........................SSSSSSSS.... ...YYY.......YYY............EEE............................................SSSS..............SSS .....YYY...YYY..............EEEEEEEEEE.......................SSSS........................ ........YYYYY................EEE..........................................SSSSS..................... ..........YYY...................EEE..............................................SSSSSSSSS...... ..........YYY...................EEE.....................................................SSSSSSSSS ..........YYY...................EEE..................................................................SSSS ..........YYY...................EEE..........................................................SSSSS..... ..........YYY...................EEEEEEEEEEEE...................SSSSSSSSSS....... YYY............YYY..........EEEEEEEEEEEE..........................SSSSSSSS.... ...YYY.......YYY............EEE............................................SSSS..............SSS .....YYY...YYY..............EEEEEEEEEE.......................SSSS........................ ........YYYYY................EEE..........................................SSSSS..................... ..........YYY...................EEE..............................................SSSSSSSSS...... ..........YYY...................EEE.....................................................SSSSSSSSS ..........YYY...................EEE..................................................................SSSS ..........YYY...................EEE..........................................................SSSSS..... ..........YYY...................EEEEEEEEEEEE...................SSSSSSSSSS....... YYY............YYY..........EEEEEEEEEEEE..........................SSSSSSSS.... ...YYY.......YYY............EEE............................................SSSS..............SSS .....YYY...YYY..............EEEEEEEEEE.......................SSSS........................ ........YYYYY................EEE..........................................SSSSS..................... ..........YYY...................EEE..............................................SSSSSSSSS...... ..........YYY...................EEE.....................................................SSSSSSSSS ..........YYY...................EEE..................................................................SSSS ..........YYY...................EEE..........................................................SSSSS..... ..........YYY...................EEEEEEEEEEEE...................SSSSSSSSSS....... I hope that clears things up.
Feb 11, 2010. 2:52 PMDoctor Who says:
dgm copied this guns trigger http://www.instructables.com/id/Dragons_Roar_Crossbow/
Mar 16, 2009. 4:19 PMknex_builder_freak says:
It's Okay but ask DGM if you can keep this up...
Mar 20, 2009. 12:01 AMBartboy says:
You can't copyright the way a toy is constructed...
Mar 20, 2009. 8:58 AMknex_builder_freak says:
Yes I know,but he should ask if he minded about it...
Mar 20, 2009. 10:24 AMBartboy says:
But he does not have to.' He should, but it is his decision.
Mar 20, 2009. 2:25 PMknex_builder_freak says:
Yes.
Mar 20, 2009. 8:12 PMBartboy says:
Yes.
Mar 20, 2009. 8:56 PMknex_builder_freak says:
YES.
Mar 21, 2009. 2:48 AMThe Jamalam says:
Mar 21, 2009. 7:38 AMknex_builder_freak says:
YYY............YYY..........EEEEEEEEEEEE..........................SSSSSSSS.... ...YYY.......YYY............EEE............................................SSSS..............SSS .....YYY...YYY..............EEEEEEEEEE.......................SSSS........................ ........YYYYY................EEE..........................................SSSSS..................... ..........YYY...................EEE..............................................SSSSSSSSS...... ..........YYY...................EEE.....................................................SSSSSSSSS ..........YYY...................EEE..................................................................SSSS ..........YYY...................EEE..........................................................SSSSS..... ..........YYY...................EEEEEEEEEEEE...................SSSSSSSSSS....... YYY............YYY..........EEEEEEEEEEEE..........................SSSSSSSS.... ...YYY.......YYY............EEE............................................SSSS..............SSS .....YYY...YYY..............EEEEEEEEEE.......................SSSS........................ ........YYYYY................EEE..........................................SSSSS..................... ..........YYY...................EEE..............................................SSSSSSSSS...... ..........YYY...................EEE.....................................................SSSSSSSSS ..........YYY...................EEE..................................................................SSSS ..........YYY...................EEE..........................................................SSSSS..... ..........YYY...................EEEEEEEEEEEE...................SSSSSSSSSS....... YYY............YYY..........EEEEEEEEEEEE..........................SSSSSSSS.... ...YYY.......YYY............EEE............................................SSSS..............SSS .....YYY...YYY..............EEEEEEEEEE.......................SSSS........................ ........YYYYY................EEE..........................................SSSSS..................... ..........YYY...................EEE..............................................SSSSSSSSS...... ..........YYY...................EEE.....................................................SSSSSSSSS ..........YYY...................EEE..................................................................SSSS ..........YYY...................EEE..........................................................SSSSS..... ..........YYY...................EEEEEEEEEEEE...................SSSSSSSSSS....... It does...
Feb 4, 2010. 5:03 PMNINJAboyofwisdom says:
You people are crazy...
A "Yes" competition?
Roflolmao
(Rolling on floor laughing out loud my a** off)
Feb 4, 2010. 6:14 PMknex_builder_freak says:
ahahahahaha
Mar 21, 2009. 8:19 AMThe Jamalam says:
good ;)
Mar 21, 2009. 5:15 PMknex_builder_freak says:
LoL.
Apr 16, 2011. 8:09 AMeigthwarhero says:
u will neva no wat roflmaocmeoaatnors means!?!?!?!?!?
Apr 17, 2011. 1:05 PMknex_builder_freak says:
Lol
Nov 11, 2009. 5:22 PMSpycrab says:
does this gun work good? :o
if so, i may have a whack at building this, looks pretty easy and nice :D
Mar 16, 2009. 4:07 PMgijo91 says:
please, no more snipers in pistol form. they were originally ment as snipers, so lets keep it that way
Mar 17, 2009. 12:40 PMThe Jamalam says:
it means that the mech he used was put in a pistol. why can't we post pistol-snipers?
Mar 17, 2009. 12:57 PMgijo91 says:
I'm not saying you can't, I'm just saying that some guns, such as killerk's sniper were meant to be a sniper
Mar 20, 2009. 12:00 AMBartboy says:
:o I am shocked.
Mar 17, 2009. 1:40 PMThe Jamalam says:
yeah but it doesn't stop people from making pistol forms of them. What's wrong with them?
Mar 18, 2009. 11:54 AMThe Jamalam says:
that's what i'm arguing to this guy for. i'm on your side lol
I like it. it's simple and has far shooting potential.
Mar 17, 2009. 1:32 PMDJ Radio says:
did you ask DGM for permission? either way, good gun.
Mar 16, 2009. 4:25 PMshadowninja31 says:
ok, now try making your own design!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:c101
cheese
