Introduction: Diamond Plate Belt Buckle
Picture of Diamond Plate Belt Buckle
As a grade 11 high school student i often find myself on the internet looking for stuff to do when i get home. One of the problems i encountered was the lack of clarity that some of those instructables had  so here is my attempt to create an easy to follow 'ible.
this belt buckle it the offspring of old diamond plate and some well deserved time in my shop. it is a very common shape and one of the better clothing articles i own.
Step 1: Things to Gather
Picture of Things to Gather
TOOLS:
hacksaw
bench grinder
motorized wire brush
bench vice
rubber mallet or hammer
blow torch and solder
dremel tool (optional)
sand paper
drill
sharpie marker
ball pean hammer or mallet
MATERIALS:
3x4 inch piece of diamond plate aluminium
2 nails
belt new or old it doesn't matter
Step 2: Basic Layout
Picture of Basic Layout
once all tools are gathered mark out the basic shape you want  to have holding up your pants.  be  sure to keep it simple as aluminium isn't the easiest to cut and sharp points are very annoying when sitting. i chose to use the standard 3x4 oval for now and  i may make other shapes if i find time. (a rectangle with rounded corners would be very simple but still good looking!)
all off the planing should be done on the back of the plate just to make is easy.
once the you have the pattern drawn you can begin cutting out the buckle. you can use a hacksaw or another tool i used my dremel  with a small cutting disk so i could better follow the curves dont worry if you dont get the cut too close because you need to better round the edges with the bench grinder to get the correct profile.
Step 3: Curving the Buckle Without a Vice
Picture of Curving the Buckle Without a Vice
if you have a vice go to step 4 if not continue.  now that you have a blank  disk you need to put in the curve. place two solid blocks just far appart to hold up the edges of the buckle
from there place a block of wood on top of it and hit it very hard with a hammer or mallet. you will need to do this a couple of times fo get the right ammount of curve in the aluminium.
Step 4: Curving With a Vice
Picture of Curving With a Vice
To get the right curvature on the metal place the buckle in the vice like in picture then push down and tighten the vice. This method also works with a hammer remember it takes some workto get the right amount of curve.
Step 5: Making the Belt Loop
Picture of Making the Belt Loop
to make the loop cut the head and point off of a nail bent the nail at a 90 degree angle as in picture 3 then measure over just a little bit farther than the width of your belt and make another bend in the nail.
now measure out the width of the nail on your buckle and drill two holes that the nail ends will fit into.  push the nail through and then pean or mushroom the nail on both sides so that it wont go back through and then slightly bend it over so that it wont wiggle.
Step 6: The Pin
Picture of The Pin
the pin is basically the same as the loop but like i said a pin drill the hole mushroom the thing and bend it a little. and a small ammount of solder wont hurt either.
Step 7: The Finish
Picture of The Finish
once you have the rest completed you can polish up the buckle with the wire brush or some 400 gris wet or dry sandpaper or a dremel with some fancy bits and there you have it a custom belt buckle.
my next step will be to make more patterns and designs if i can find a CNC plasma cutter or milling machine
have a gooder!
abstracted (author)2012-03-23
your solder looks lik a cold solder joint...dont think it`ll last. really rough up where the loop n pin are and try JB cold weld...great job n ible...just a sugestion.
mr.mountaineer (author)2012-02-17
Awesome belt buckle. I think id prefer stainless steel diamond plate but i would use whatever i could get a hold of. thanks for the info and if i manage to find a piece of diamond plate big enough this will be the first thing i use it for. keep the great instructables coming.
will do as long as ive got cash
Penolopy Bulnick (author)2012-02-15
Cool! How did you get those ridges on it?
by ridges do you mean those "diamonds" those are already in the aluminium hence diamond plate
Oh, I see it! The pictures kept showing it from the side and back so I got confused, but I see it now :)
About This Instructable
5,972views
44favorites
License:
Bio: i feel that if given the proper resources and adequate time i can build anything!
More by Jordan Dyck:diamond plate belt buckle
Add instructable to:
