Distance Measurement With 2.4 Ftf and Ultrasonic Sensor
20,410
26
20
Posted
Introduction: Distance Measurement With 2.4 Ftf and Ultrasonic Sensor
this is very simple arduino circuit with HC-SR04 ultrasonic sensor and 2.4 inch tft display, powered by arduino uno.
the arduino uno calculate the distance and update the display every 1 second.
watch this video to see how it works.
Step 1: Tools and Parts
the only tool we need is a pc with arduino IDE.
in this example we use the Adafruit_GFX library to use the tft display.
required parts:
1 ARDUINO UNO + 2.4 TFT (you can use any arduino you want..)
1 ultrasonic sensor
20 jumper cable wires
1 6v battery or power supply
Step 2: Conecting and Coding
the tft shield can fit to the arduino but the ultrasonic need some wires.
connect the ultrasonic sensor trigger pin to the arduino pin 11
connect the ultrasonic sensor echo pin to the arduino pin 10
connect the ultrasonic sensor vcc to 5v
connect the ultrasonic sensor gnd to the gnd
upload the code and make a test
  • Microcontroller Contest
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
19 Comments
Adafruit_ILI9341_8bit_AS.h is not on this planet. can't find it any where...............
where are the libraries you used? i downloaded the code but cmpilation gives error for your libraries not found.
I got everything done, but that flashing of display is not looking good for eyes. can't we make display static like other LCD displays?
I need help in connections as m new to it....my code is ready but i am getting stuck i middle of circuit connections please help
hello,
i cant find the correct library's, i found the adafruit gfx library but i can't find the library "Adafruit_ILI9341_8bit_AS.h" anywhere on the internet,
could u help me please?
thanks
joris
https://learn.adafruit.com/adafruit-2-8-tft-touch-shield-v2/graphics-test
can you give me this library?
and Adafruit_GFX_AS.h
please send at cs.gpinstrument@gmail.com
Could you send over the necessary Adafruit libraries to jatr7044@colorado.edu
