3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY - Replace Broken Laptop LCD
Replacing a broken laptop screen is more often than not, a very easy project. If you have a broken screen, don't jump on ebay and sell it for considerably less than it's worth. Instead, go to ebay and try to find the replacement LCD, the entire cover for your computer, or even better, your computer with a blown motherboard but intact screen! The later case, you not only get a new screen, but extra memory, a backup hard drive and perhaps even a WiFi card you didn't have before.
It helps to know your computer. If you don't, do your research first. Some laptops have the LCD glued (epoxied) into the frame. In these cases it's usually much easier to replace the whole cover. Most don't have this problem though.
I'm going to show how easy it is with an Apple iBook G4. I've also replaced the screens on Panasonic, Gateway and other laptops just as easily.
Step 1Gather Supplies
Gather Supplies
What we'll need, besides the replacement LCD of course, are the tools to open the display enclosure. In this case, we'll need a tiny magnetic phillips screwdriver, a size 1.5 allen wrench and something to pry apart the snap together frame.
The later can be a couple of small (tiny) flat edged screwdrivers, a metal ruler or paint scraper with the edge filed to a sharper edge, etc. In my case, I use the tools that were included with a battery replacement for an iPod. The tools alone were worth the cost of the battery!
For some, a pair of tweezers would help.
214 comments
1-40 of 214next »
Apr 17, 2012. 3:12 PMpblanscet says:
Thanks a bunch! I'm planning to repair a laptop for a friend, and this was all the enlightenment I needed to do so!
Nov 28, 2010. 5:36 AMSkippitte says:
Recently my screen started getting dimmer. I tried a "hard reset" on it and when I start it back up it's perfect!... for about a minute.. then it goes back dim. I have check all my settings, did a system restore on it.. any ideas?
Feb 7, 2012. 9:54 AMOCkikin says:
Hello i have been a computer tech for over 10 years and sounds to me like a faulty inverterboard and or backlit bulb, But most likely the inverter. Could be the screen cable itself but unlikely.
Jan 2, 2011. 5:14 PMpatt39 says:
It might be a faulty connector, try open your laptop and reconnect it.
Jan 2, 2011. 6:53 PMSkippitte says:
Sorry but any idea Wat the connector would look like?
Jan 2, 2011. 7:12 PMpatt39 says:
It varies model-to-model. but it is always the connector that connects your screen to the bottom part, reconnect every connector that does just that.
Jan 8, 2012. 5:14 PMjtmjjj says:
Hi.
I recently replaced the screen on my HP dv6-3216. It seemed easy enough and saved me over $150, but now it won't turn on. At first the light around the power cord was lit, but as I kept checking connections inside I finally wound up with nothing.
I did break one of the cable clips, but secured it with tape. Help me please.
Jan 6, 2012. 1:36 PMmalvadoo says:
Hello, I recently replaced my HP dv6214ea LCD matrix with this one http://whitenergy.com/Matryce_do_laptopow/CCFL/LCD_panel/CCFL_15_4_1280_800_matte/product/07362/113/117/
But results its bad, colors is to warm, little flashing and dots are to large. How I can fix it, and there are problem?
Oct 13, 2010. 9:08 AMlithodir says:
Hey, I was wondering - I have an old ibook G4 with a good LCD but an old operating system. I was considering buying a used ibook G4 with a higher operating system, but a cracked LCD and putting my old screen into the cracked screen. One issue is that I inherited my ibook from my sister, who bought it in New Zealand and I have a power converter on the end of the plug in for the power cord, but everything else seems the same - do you know if they all use the same parts all over the world? Assembled in Taiwan model A1055 - if that's helpful... I'm really keen to try this! Thanks!
Aug 23, 2010. 12:14 AMTracker007 says:
How you doing Im sorry to bother with rookie questions but I need help asap. My laptop lcd is cracked and needs to be replaced. I have a HP G60-230us and I opened the laptop and found that its a Samsung LTN160AT02-H02 I found a good price on a Samsung LTN160AT02-B02 - $95 for a new pull? whatever that means. I hope it will work, does the H02 and B02 mean a different configuration or does it refer to a batch of some sort. Thanks to all whom can help and God bless.
Jul 16, 2010. 6:41 AMoompieter says:
I have a Toshiba P100 with a broken screen - a WSXGA+ with resolution of 1680x1050. I can buy a replacement screen - a WXGA with a resolution of 1440x900. Everything else on the two screens are identical. Will the lower resolution works?
Jun 18, 2010. 10:45 AMprasasht says:
Hi - I bought a screen from ebay which didn't match the model I wanted to replace but on confirmation from the seller that it would work, installed it. Looks like I was able to successfully install it but the issue is that when I switch on my laptop the screen appears grayish (I can see the desktop) looks like each alternate pixel is white. But as soon as I try changing the display properties on the screen the screen becomes clear and perfect. It works fine in all display settings its just that it triggers something. Also I observed that if I hibernate the machine the screen remains clear. But if I shut down or restart it it again goes back to the grayish look. Would appreciate if you could help. Model Inspiron 9300 (17") Original screen - LG171WX2 (B4) replaced with - LP171WP4 (TLP2)
Jun 12, 2010. 2:20 PMalbizzy114 says:
if i find a screen in the housing, would it be easier if i just replace the housing instead of just the lcd? I have never done anything like this before, but the screen just cracked today, and this is actually a borrowed computer. I'm trying to fix it on my own.
Jun 13, 2010. 7:22 AMalbizzy114 says:
It's an ibook G4. I just broke it yesterday, stumbled across your step by step. Looked on Ebay and found an auction that was going to end in within hours that no one had bid on. I ended up getting it for REAL cheap. I guess I just got lucky
Jun 11, 2010. 4:03 PMjambalee says:
Hey Las Vegas, i recently replaced my Acer Laptop screen that i had broken myself by closing lid with something in it. the replacement was easy enough, after installation my computer seemed to turn itself off when i touched it or moved it. after my computer added the new hardware, it seemed to work a little better. almost every time i turn it on now, power will go off, i restart it, someitmes it starts right up, i've also had it do a system repair and also start up in the safe mode. i asked the company i bought it from, and they suggested maybe the sleep button/sensor may be been disturbed upon new installation. they suggested removing the screen and reinstalling. my questions is where would this sleep sensor button be behind the lid when i remove it. or could it be somehting else. just before this happened, i was having a problem shutting down my computer. it would take forever so i would pull the battery to turn it off, then have to go thru safe mode when restarting.
Jun 5, 2010. 12:42 AMsamygold says:
Thank you for your reply I already connected an external monitor and itworked fine so its definitely the monitor, how can I identify the problem exactly and fix or replace the faulty part? Regrd samy
Jun 5, 2010. 5:34 AMsamygold says:
Thank you for your reply , I hope it's a connection problem but if I opened the screen casing wouldnt that void the warranty? I'm puzzled now what to chose? the RMA which it seems unlikeley because I live away from the purchasing place OR fixing the screen my self and vilating the warranty if it's useful>>! Thanks samy
Jun 4, 2010. 3:10 PMsamygold says:
I have ASUS G73JH-A1 notebook and after 2 weeks I had an LCD sudden problem which is the screen display divided into 2 parts ;the left side was white with vertical black moving lines and the right side has rainbow t colors image as in these links show : http://j.imagehost.org/0028/DSC04422_600_x_450.jpg http://a.imagehost.org/0443/DSC04424_600_x_450.jpg http://h.imagehost.org/0264/DSC04426_600_x_450.jpg http://www.youtube.com/watch?v=TlZo25aPWps&feature=related Please help me identifying what causes this problem exactly and what to do to fix it? Thank you My best Regards Samy
Mar 13, 2010. 9:26 PMTucuquito2 says:
Hi, I tried to fix my friend Sony Vaio Vgn-Z590 put new bezel and look great, very expensive by the way" bad news its that I put it back together and now the LCD won't work work, it look cracked on one corner small line and it atent to show something but then it goes gray and nothing comes up, I took it apart several time and tried everything, same results, I checked the LCD on ebay and it cost over $500 it's a rare 13.1" If any body could help me on finding something cheaper, Please help me out!! Oh one more thing there are two contact on the sides by the hinges I try to set them every way possible and nothing if any body knows how they are suppose to be, please, I think it will be cheaper just to loose a friend!!
Feb 12, 2010. 4:02 PMILEDWARDSJR says:
Your instructions were very helpful.  This afternoon I replaced the lcd screen in an IBook G4 (14" mid 2005)  The only snag was that the four screws on the ends of the outside case were #6 Torx screws rather than Allen head screws - fortunately I had a set of small sized Torx screwdrivers.  Otherwise the removal and replacement went through without a hitch.  Thanks again.
Feb 7, 2010. 3:31 PMpbenson3000 says:
Hi there:
I have a MacBook Pro, 17 inch and there is a crack at the base of the display housing (the metalic/plastic frame around the screen that houses the LCD, with a hole in it for the camera, and writing MacBook Pro along the base).
Is this replaceable, looks like its held in place by a couple of screws?  Is it worth taking to mac?
Nov 16, 2009. 8:25 AMjonathon says:
Fantastic! Did it in about an hour. Felt very empowered by this!
Oct 7, 2009. 4:07 PMJCO72 says:
The first time I did this was with a Vaio with a bad backlight.  I screwed up the LCD while taking it apart.  I replaced it with the screen from an older vaio with a blown motherboard.  The problem was, the replacement screen/panel was slightly smaller than the original... it didn't fit in the bezel, and the screws didn't fit.
I ended up using hot glue.  Laugh if you will, but it lasted for a few years as a backup, until I tore the screen down to put in on an overhead  projector...
Oct 7, 2009. 8:45 AMjim-leee says:
Hey, <br />Great tutorial, Replacement was a breeze! ThX! Your tutorial and <a href="http://www.screencountry.com">screencountry</a> online site saved me tons of $$$, their prices cannot possibly be beat! and my HP is on and running like new again! Thanks to you and <a href="http://www.screencountry.com">screencountry</a> once again! Great job guys!
Aug 27, 2009. 5:18 PMtincup845 says:
My ibook screen cracked so I bought a replacement Lcd online and followed online instructions to replace it. Everything seemed to go smoothly while i was doing the repair, but after it was complete, i powered it up and the screen did nothing for about 20 seconds. Then it turned to a dark gray. It stays that way no longer how long i wait. It makes all the right sounds like the start up jingle and everything. can you please help?
Jul 29, 2009. 1:04 AMKasm279 says:
2 things my laptop looks like thet iBook (if only i had one D:) and(as a future reference) the clock memory and such is called PRAM (perimeter RAM), not CMOS :D
May 16, 2009. 2:44 PMinrumford says:
Is there a way to tighten the hinges as the lid has a tendency to fall back a little
May 16, 2009. 8:00 PMbweezy says:
LasVegas, I replaced the LCD on my Compaq Presario A900. The screen works fine, but now windows isn't functioning correctly. It's mostly non-responsive and I can't even get it to shut down on it's own, I have to do a hard reset. Any ideas?
Jul 29, 2009. 1:13 AMKasm279 says:
install linux?
Jun 27, 2009. 3:10 PMdougworm says:
"LDC" means Ladder Day Computer
1-40 of 214next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:LasVegas
