3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
diy aquarium top filter
Step 3Step 2 - sticking everything
You can use any waterproof sealant for sticking all the materials................................silicon glue is recommended as it is the most safest..............
Start by first glueing the partition of the filter box...........................dont forget to leave the downside open for the water flow.......................
Then glue the elbow coupling of the pipe to the inlet of the filter box.......................
Fit the pipe to the pump...................if the diameter to the pipe is larger than the that of outlet of the pump, you can use any soft bendable pipe in between to fit both the elements................
after the silicon has dried off, fit the pipes and the filter box together, install it in the tank and start the pump to see if all is working well.......................
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kunalmittal
