3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
diy custom t shirt
Step 4Ironing time
ironing time
now you have to peel the front thin side from the thick "photo papery" back. see picture. then take out you iron, put it to full/ high heat.let it get as hot as can be. iron the spot you are going to lay the design on. this makes for a better surface to stick to. now place the design on the shirt, put some parchment paper on top of the design. now place the HOT iron on the design that is now under the parchment paper MAKE SURE TO GET THE EDGES OF THE DESIGN or you design won't stay very long on the shirt. take the iron and parchment paper off let the design cool in about 30 more minutes repeat the ironing steps this will ensure of a great hold / stick. the black looks a lot lighter than the shirt but when you do the iron process all the colors are bolder and darker
2 comments
Apr 11, 2012. 1:43 PMbenpic10 says:
A heat press will produce better results
May 20, 2010. 7:47 AMSantaB says:
I think I have that same, exact iron at home...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
66
Author:slimguy379
