my pool is a 16' round 42" deep. think it holds about 4000 gallons. basicly between all the people, and our 2 filthy dogs, the little cartridge filter was not cutting it. it hangs in there for the 1st couple weeks then the water just gets too nasty. even though i come home and sray it off every day and change it once and a while. the filtration setup that comes on the pool should probly only come on somthing with a few hundred gallons. whatever, i think it sucks. in the picture obviously im also dealing with some algae.
Remove these ads by
Signing UpStep 1: The basics
how do they work? well its actually really simple. a "normal" sand filter is a sealed container half full of sand, water is forced though the sand by the pump. ya its that simple.
how exactly? a pump forces the water into the top of the container, usually through somthing that spreads it even so its not just a jet of water blasting a tunnel in the sand, you want a nice even sand bed the water has to go through. in the bottom there is somthing that usually looks like a a bunch of little pipes with slits in them the sand cant fit through that connect to a big pipe, that is the outlet where clean water comes out.
Visit Our Store »
Go Pro Today »
wont hurt any thing really the water in the pool dilutes it any ways
I cannot remember what our equivalent doses my stepdad used though (20 odd years ago!), but Google will help you find it for you!
If you were using a cartridge filter, whatever the size of the pool, you will end up with a green pool unless you declare chemical warfare on it - the pores on the filter are still to big to filter out the smallest algae, and even after superchlorinating the water, and everything is dead, the filter just cannot take the crud out of the water!
My parents ended up getting a 6000 gallon-ish pool complete with a sand filter, though the pumps have a tendancy to die after a few years - and given the price of a pump and filter system, compared to yours, this could be a great replacement idea.
A question; do you have a method on hand to flush the filter? - push a couple of dozen gallons of water the "wrong way" through the sand, and dump the outflow (don't pump it back into the pool whatever you do!), so it resettles the sand - and the backflow will flush a load of crud out from the sand and refresh the filter!
