loading
loading
Picture of diy wall snowboard rack
this instructable is how to make a snowboard rack out of scrap acrylic glass, so you can hang them on the wall.
if you don't feel comfortable working with heat/torch and power tools this might not be the best one for you.
Step 1: What you need
2 pieces of acrylic glass around .25 inch thick, 3 to 4 inches wide and 24 or so inches long.
butane,propane,or mapp gas torch or a heat gun.
clamp to hold acrylic sheet while you drill it.
4 to 6 screws long enough to mount these to the wall
drill and bit that is smaller than the head of the screws you are going to mount it to the wall with.
piece of scrap wood to bend the heated acrylic around. should be ~1 inch wide or so.
you can use this same piece of scrap wood to clamp the acrylic to when you drill it.
Step 2: The acrylic
Picture of the acrylic
you can get acrylic at lowes or home depot or window places, and often they will give you the scrap.
i got 4 pieces of .25 inch 4 inch wide 24 inch long for free.
if you need to cut your pieces you can score it with a awl or razor knife allot and then snap it.
SinAmos5 years ago
Bike hooks work for me. Thanks.
thisisaric6 years ago
You can also use two bike hooks from homedepot for around $1.50 each, only thing is the board wont be flush against the wall.
