don't throw away bad head phones! fix them.
don\
my headphones almost always break in the same place. instead of chucking them and shelling out $10 or $20 bucks for a new pair, i bought a few small pieces and fixed my old pair. it's not too hard if you have some time.
Step 1Gathering supplies
gathering supplies
these are the tools i had near me.
it's completely possible for this to be done with alternative tools. i've heard of people using fingernail clippers to work with wires, and when i don't have strippers around i use the wire cutters on my multi-tool.
-heat shrink
-new 1/8" jack
-soldering iron
-wire strippers
-solder
(also, later on i discover a decent knife was very handy.)
27 comments
Jun 23, 2011. 12:07 PMldeakins1 says:
What is the New piece called so i know what to google for?
Feb 8, 2011. 8:47 AMVinsu says:
Wow... In the end this looks pretty decent... Nice job!
Just fixed my own headphones couple of days ago and I really wish there would have been some heatshrink around. Right earphonecord was partially disconnected, cause: cord was on the floor, I rolled my seat on it and when I lifted my headphones... This action prodused one angry human being and lots of newly discovered curse words because of one little piece of wire. About an hour after when I discovered my soldering supplies the job was almost done; reconnecting wire to the speaker was easier than i thought, thanks to Seinheiser for making some of it's products easy-to-dismantle and to put back together...
ANYHOW (babbling like my aunts), heatshrink added (like you did) on wire-to-earphone connection point would have made my repair outcome much nicer looking. Your instructable reminded to buy this godly stuff next time when given a chance. Insulating tape meld hot with lighter made it tough to break again but this cruel outlook makes the baby-Jesus cry...
Nov 15, 2010. 8:27 AMSteve Potman says:
Very clean job. It was done very well and looks to be quality. This is a really really good idea. I have to give you a lot of credit for this. I just recently got heat exchangers and heat shrink so this will be a good use for them as well. Thanks again and good luck to you.
Oct 22, 2010. 2:07 AMShinji Ikari says:
You really are a genius sir! thanks!
Apr 13, 2010. 3:47 PMRy_Ry says:
 Yes, Which part does the earth connect to? The largest bit?
Apr 13, 2010. 3:31 PMRy_Ry says:
 I am going to do this right now =) I just went down a brought a new audio connector for it, Too bad i don't have any heat shrink
Jan 6, 2010. 10:31 AMmoorrese says:
 I hope this works for me, i've gone thru 4 pairs of earphones in a month, im starting to think my ipod is shorting them out, hope all goes well.
Dec 28, 2009. 3:05 PMmad_larkin says:
Hey,
Firstly:
Thank you for the tutorial. It hadn't occurred to me to replace the mini jack....durr.
Secondly:
I managed to figure out which cable went where by dissecting the old mini-jack. With my Steal Series Sound 5HC head phones:
img686.imageshack.us/img686/7565/jacklayout.jpg
The connector in the centre of the jack is the Red cable, the connector directly opposite is the Blue cable and the larger of the three connectors is the Ground.
I wouldn't assume this is the same for everyone. All I can advise is you dissect the old jack and compare it to the cables you have.
Sep 11, 2009. 4:25 AMzetlin says:
erm could u provide a diagram for the soldering bit having trouble figuring out which wire goes where
Jul 6, 2009. 12:52 PMyellowsnow4free says:
One last tip: if you use the heat shrink, tape up the end of the headphone jack (the side that goes in the mp3 player). This will keep the rubber on there from melting. I used black electrical tape, which worked good except that I needed to wipe off some of the black residue when I removed the tape.
Jul 2, 2009. 8:58 AMyellowsnow4free says:
I'm still amazed this actually worked. I'd like to add what I learned though. In my case, I didn't buy a replacement jack, I just used the old one. I cut the headphone cord at the jack base, then took apart the jack until it was just the end. Then, I saudered the wires onto the jack. It looked awful, but when I plugged it in it actually worked! Note: simply touching the wires to the appropriate spot on the jack didn't work, you'll need to sauder the wires onto the jack. Lastly, if you use the heat shrink tubing, you might want to slip them onto the wire before saudering, just in case they won't fit after the jack is on. Great instructible! I'll never throw a pair of headphones away again!
May 6, 2009. 9:44 AMbig_ears says:
i live in Toronto, ON. Where can I get replacement jacks? Our "'Radio Shack is now called the The Source by Circuit City doesn't have them. Any suggestions? Preferably locally so i don't have to pay for shipping or wait :)
Thanks!
Apr 23, 2009. 10:47 AMyouloveinsomnia says:
The notation didn't help. It would've been nice for you to have mentioned what wires to solder to what part of the jack.
Oct 13, 2008. 3:18 AMcicloid says:
I'm gonna try this DIY, because my in-ear have died, but I have some other headphones with just the connector damaged, so, maybe tomorrow I could start with this one...
Jun 4, 2008. 7:03 PMDIY Dave says:
How do you know if it is a problem with the jack or something else? How much does the jack you used cost?
Jun 6, 2008. 2:41 PMDIY Dave says:
Thanks for your help
Jun 2, 2008. 4:08 AMkillerjackalope says:
Actually that looks far slicker than most headphones, the connector does anyway, be a bit bulky for some items but cool nonetheless Anotehr good trick to prolong the life is to add a thin piece of heat shrink or tape for an inch or so after the larger casing, this make bending a bit less strainful on the inner cables so they live for a lot longer, I tape all of my headphones when I get them and since starting that they've all died from blowin drivers or damage via standing on them...
Jun 1, 2008. 10:11 PMthewoodcarver says:
I just take the magnets out of the cheap ones ...My good ones got broken at the very spot yours are broke at and I do have a few 1/8 inch jacks somewhere in the garage now I will save $25 or so .I have the shack butane iron it is OK for some things but sucks at others ..like small work... would lose it but a present from the kids
May 31, 2008. 8:56 PMTrans_Am says:
I usually just cut all the rubber off the old plug, re-solder the connections, and cover it in glue. Sometimes I paint the glue. Its ugly(er) but cheap. Nice idea though.
Jun 1, 2008. 2:45 PMGorillazMiko says:
Sweet. I don't throw 'em away, I just throw them in a drawer or something. Nice job, what kind of soldering iron is that? It looks cool. +5/5 stars.
May 31, 2008. 8:23 PMLinuxH4x0r says:
Very nice, I do this all the time
May 31, 2008. 8:15 PMacaz93 says:
that's what i always do , great 'ible ! kinda resembles mine
May 31, 2008. 7:47 PMbumpus says:
that looks very clean, high five! (i'm mixing it up, instead of saying "5/5" or "10 stars", I'm giving out high fives)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kazaam
i feel armed with a hot glue gun and butane soldering iron. . . and completely lost without my gerber and surefire flashlight. i'm a theatre techie on hiatus.
