Remove these ads by
Signing UpStep 1Gathering supplies
it's completely possible for this to be done with alternative tools. i've heard of people using fingernail clippers to work with wires, and when i don't have strippers around i use the wire cutters on my multi-tool.
-heat shrink
-new 1/8" jack
-soldering iron
-wire strippers
-solder
(also, later on i discover a decent knife was very handy.)
what i was trying to do was re-solder the old broken head-jack because i thought that was the problem. it was impossible to get to it without getting tremendously angry and just ripping it apart lol. i didn't even think about buying a new top because i thought it be more complicated. this was way more simpler than i thought! I had the same feeling as you did in the end! XD thanks again!
Just fixed my own headphones couple of days ago and I really wish there would have been some heatshrink around. Right earphonecord was partially disconnected, cause: cord was on the floor, I rolled my seat on it and when I lifted my headphones... This action prodused one angry human being and lots of newly discovered curse words because of one little piece of wire. About an hour after when I discovered my soldering supplies the job was almost done; reconnecting wire to the speaker was easier than i thought, thanks to Seinheiser for making some of it's products easy-to-dismantle and to put back together...
ANYHOW (babbling like my aunts), heatshrink added (like you did) on wire-to-earphone connection point would have made my repair outcome much nicer looking. Your instructable reminded to buy this godly stuff next time when given a chance. Insulating tape meld hot with lighter made it tough to break again but this cruel outlook makes the baby-Jesus cry...
Hey,
Firstly:
Thank you for the tutorial. It hadn't occurred to me to replace the mini jack....durr.
Secondly:
I managed to figure out which cable went where by dissecting the old mini-jack. With my Steal Series Sound 5HC head phones:
img686.imageshack.us/img686/7565/jacklayout.jpg
The connector in the centre of the jack is the Red cable, the connector directly opposite is the Blue cable and the larger of the three connectors is the Ground.
I wouldn't assume this is the same for everyone. All I can advise is you dissect the old jack and compare it to the cables you have.
Thanks!
it's sort of a process of elimination.
both the right and left side were going in and out simultaneously. (if it was only one side i would jiggle the cable going to it to see if it it went in and out. and then i could narrow it to just one earbud.) i sort of 'gently' twisted the cable and check it for nicks and such, and the only time it got better or worse was when i jiggled it right at the bend in the old jack.
then i tried a different set of headphone on my player to see if it was the player's jack. . . they worked fine. . . and as a final bit, i tested the sketchy headphones on a different player and had the same problem with them. i got them to go in and out by fussing with the cable right at the jack.
the one i bought from radio shack. . . just under $4, and i went for a higher grade one. . . so there were definitely cheaper ones.
1/8 jack
(http://www.action-electronics.com/weller.htm#Butane)
i love the butane iron, i started on the cheaper radio shack ones, and then eventually upgraded. i prefer it over electric any day.
