3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
down and dirty screenprinting for under 10$
Step 7Mixing Ink.
Mixing Ink.
Depending on humidity, temperature, paint quality, age, etc., ink will have to be mixed differently.
Too dry, and the ink will dry up in the screen in between passes.
Too wet, and the ink will run through the screen and ruin our substrates.
It will probably take some time to get the perfect consistency, be patient.
Here in the very dry desert, I mix about 1 part retarder for 10 parts paint.
Dark colors printed on light colors work best for this method because there is only one opportunity to pull the prints before moving the screen, and no way to layer lighter colored inks.
Everything is ready.....
6 comments
Aug 6, 2009. 8:45 PMdarkstar1 says:
Haha, retarder...
Mar 12, 2009. 11:19 AMrevanwhitt says:
I just need to know what type of paInt was used. revanwhitt@gmail.com
Mar 12, 2009. 6:57 PMDimitrios says:
I would like to know too. I see it's 'enamel' paint, but isn't that oil? I thought we should look for 'latex'?
Mar 13, 2009. 9:36 AMMoto13 says:
Dimitrios, Yep enamels are oil-based, latex is water-based... and you need solvent to cleanup the oil-based.. but they usually launder better, less washout. just make SURE whatever you use, to heat-set (ironing works) the print before washing, or it will fade quick.. jesusfreakgirl93, tight weaves print detail and edges better, but for simple images loose is ok, but wont look as good... Happy printing! ;)
Apr 7, 2009. 8:51 AMdano27 says:
I have a question if the paint is water based does not erase the image when the garment is washed? davelazquez@hotmail.com
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
85
Author:woodenshoespress
