Drawing Robot How to Make
Published
Introduction: Drawing Robot How to Make
About: Xxxx xxx xxxxx xxx xx xxxxxx xxx xxxxx xxxx xxx. Xxxx xxxxxx xx xxxxx xxx xx.
to make this robot you will need:
Step 1:
first you will take part V and connect it to part O with 2 parts of A and B (see intro for part guide) and put a part R and part L on the end of the motor.
Step 2:
next take part Q and slide it through part W with a part C on the shorter end and part N on the other first then part U.
Step 3:
put the wheel and axle from step 2 through the middle hole of part O with part U then S on it.
Step 4:
now put one end of part K on the left over axle with part T and L between K and O
Step 5:
then put part F on top with 1 parts A and B
Step 6:
now you connect the battery pack with 1 AB to part F
Step 7:
next connect part I with part O and part E and put part P in part K with part D on the other end
Step 8:
now connect part G to the battery pack with 2 AB(one A and one B)
Step 9:
now put part Q through part G and have 2 J on both ends with part L the same way.
connect part M to the 2 parts J.
connect part H to part M
and you are done just take a marker wrap it with a rubber band and stick though the hole made with parts M and H.
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
