Introduction: Dresser Drawer Blade!
this is my first instructable and i made it after i made the blade so plz bare with me.
Anyway this is the blade that i have created from the metal scrap i found from the bottom of my old dresser. although the blade did not come out the way i had planned it is strong, sharp and still cool looking.
Step 1: Get Your Scrap.
first you begin with the base of the drawer. as you can see i bent the bottom part up but if you dont want the hassle you can remove it easily.
Step 2: Fold the Steel
after heating it up in your custom forge (not required though reccomended) you pound the sides flat until you have a flat peice of metal about 4 inches wide. then you turn it over on its side and fold it over. (some may find this similar to that of japanese steel folding, though not as neat.)
Step 3: Sharpen
while it is athentic in trying to sharpen the blade by hand with a file or whetstone( and i usally prefer that) if you are short on time or patience use a hand grinder at a 45 degree angle. both sides would be preferable.
Step 4: Fine Sharpen and Sheath.
after the rough sharpen just fine tune the edge a bit and put the blade into a safe dry area for awhile. after the blade is heat forged it tends to have rust on it. however if you quickly make a sheath for it and clean it reguraly the blade will be fine. (these are before but u can also ingrave them fairly easily one they turn the brownish burnt color. this is Daeomonklosa or demon claw) If after reading this instructable u have made a version of ur own, plz send me a pic or link so I can check it out
