It is a pressurized stove that does not need a pot stand. It has a large fuel capacity for a long burn time but can be adjusted by simply using less full. It is more durable than most stoves if its type.
It is heavier and larger than a lot of alcohol stove designs.
This is a tutorial on making one with items I had on hand, not with the best tools for the job. This is just to help show the ease in building.
I selected the aluminum bottle from a venom energy drink. Any aluminum bottle should work with this design, but I prefer venom. These have thicker walls than any beverage container that I have found. This make for a heavier stove than others out there, but it is much more durable. These bottles also work great as fuel containers. I chose not to remove the paint. I kinda like the way it looks with it, but simply sand it off if you wish.
Remove these ads by
Signing UpStep 1Select bottle.
I lit the inner fuel first letting it heat up, then lit some of the jets, then they finished lighting themselves. It was ready to "bloom" at 1:45 and boiled water in 3:30. I then added more water so the orig. 2 cups wouldnt boil away, I filled the GSI 1.4 litre pot almost to the top. which stoped the rolling boil but let me continue with my test. I let the flame run out totally which was at 23:30. As a guess after i filled the pot to the top, id say the added water was back to a boil in less the 5 min.
I havnt figured out how much fuel it holds and dont even know if its efficent. But im impressed with the amount of time it burned for, and id imagen i could add less fuel if i only need a few mins. of burn time.
Just for future ref. id leave them alone, just press fit together. I was useing Alcohol and not HEETbut i seriously doubt it would make that big of a diff. Still got 16 min. of run time which is more than enough. Like i said in my last post i didnt measure the exact amount of fuel, just filled to the same spot each time i tested it. and again used 2 cups of water to start off testing and finished with a 1.4 litre pot full to time the exact runtime.
Great litle stove over all, cheap, if not free. fuels easy to find and cheap. Worth messing around with because its so simple. just dont be stupid and make the outter to tall ti fit inside your cook kit.
second was pure AWESOME
