Duo Swing
417
12
Posted
Introduction: Duo Swing
Don't know what to do on a lazy day with 2?
Well I found the solution... Swing away with the 2 of you, you'll never get bored again
Create your own duo swing, it's not that hard and not at all complex.
Go and start : create your own swing
Step 1: Materials
- 12 spring locking clips (2mm)
- 2 special iron arch
- 2 x10m cord
- thin wire
- 3 aluminium tube (diameter 2,8cm – lenght 57cm - thickness 2mm)
- 2 aluminium tubes (diameter 5cm – lenght 113 cm - thickness 2mm)
- 2x strong cloth(66cmx113) and piece of cloth ( 17x17)
- drill
- bore 2,5mm and 8mm
- Pyramid bore 30 mm or bore 30mm
- Sewing machine + chalk
- needle and thread + head pins
- scissors
- rule
- compass
Step 2: Frame
- Grab the 2 tubes with diameter 50 mm
- drill a hole with diameter 10 mm all the way through, along 30 mm from each side
- drill also a hole with diameter 10 mm all the way through, in the center of the tube (565 mm)
- grab the 3 tubes with diameter 28 mm
- drill a hole with diameter 2.5 mm all the way through, along 5 mm from each side
- slide the small tubes through the holes of the large tubes
- take 6 spring locking clips and lock the ends of the tube
- now drill as close you can to the edge of the tube (each side)
- and plug the other spring locking clips in the holes
holes for to hold on spring locking clips
- drill a small hole in the beginning of the tube (one side)
- knot the thin wire(10cm) through the hole and knot the other end to the locking clip
- do the same as the previous one, above the holes
- 1 tube both sides (6 small holes)
- 1 tube one side (3 small holes)
- and get the locking clips fixed
The enclosure is ready
Step 3: Coating
the steps are shown in red on the drawings
- take the to slides strong cloth and put them on each other
- draw the pattern on the cloth and cut it to size (stand in cm)
- sew three sides of the cloth on 1.5cm
- then turn the cloth inside out
- sew the last side to 1.5 cm and cut it off nicely
- give an angled cut in the corner
-draw the inside pattern
- fold the cloth inwards and sew them around
- cut in the middle of the side a gap of 5 cm, and also the other part of the inside cartridge is (be warned: Stay 1,5cm from the side)
- sew the inside patron
- grab the extra piece of cloth
- sew the two sides
Now it is ready
Step 4: Package
- insert the tube (diameter 5cm) into the cloth
- put in each side of the tubes through a rope
- slide the small tubes through the holes of the large tubes and insert the cloth
- and secure them with the locking clips
- knot each special iron arch on a rope
Step 5: Getting Ready
- insert the small tubes in the large tubes ( 1 small tube left)
- roll cloth together
- hang the last tube to a spring locking clip
- roll pieces of rope together
- turn 2x a loop around
- insert the special iron arch through the loop
- tie the coil with the other end of the rope
- watch the movie tie
- roll the scraps of rope on and put them at the bottom
Step 6: Hanging on the Tree
- make everything free
- make the seat
- throw the rope over the branch
- cross the rope 2 times
- Make a loop with the rope
- insert it through the special iron arch
- knot it to the end of the rope
- hang the swing at the same height
fluctuate
Step 7:
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
nice work! this is such a clever idea, thanks for sharing!
