Introduction: Eagle-my Very Own Paper Plane
hi this is my first instructable. i have experimented for a month trying to get a good plane to put on instructables. so well yeah
IMPORTANT-some steps can get confusing, so use the pictures. the pictures match with each step/direction
Step 1: Step 1- the Main Body
fold about 1 inch up the long side. (if you have a lined paper, line up the lines for a better fold)
then fold in half the "hamburger" way
unfold
fold the corners to the point where the lines intersect
fold corners up against the middle crease
fold the bottom corner to where the corners from the previous step meet
flip over
fold in half to the outside
Step 2: Step 2- the Wings
you should have this
fold the wing down, keeping the crease parallel to the bottom of the plane. the crease should be where the corner is
repeat on other side
fold up an area where the little triangle at the end is. the crease should be parrallel to the top of the plane
repeat on the other wing
open up the plane. you're almost done
Step 3: Step Three- Last Bit
fold the triangle at the end down, then tuck it under the wing.
repeat
you're done yay
