http://www.artiswrong.com
Remove these ads by
Signing UpStep 1Overview
This instructable will leave you with a nice copper etching of a digital image of your choice.
Along the way, you will:
Do some digital image editing and manipulation
Laser print your image onto a transparency
Iron the transparency onto a copper clad board
Chemically etch the board
Ready? Onwards!
For photos, the thinnest board works best, and is easily cut with a razor blade and edge, or paper cutter.
The fiberglass backing could be any color, unfortunately. Some very thin (flexible) PR4 I ordered had solid black backing, which is perfect for photos. Just remember that you will have 2 "colors" - copper, and the background. In some cases you may want to invert the picture and slightly alter the color "levels" to maximize desired detail.
Thicker PR4 might not fit in some picture frames, but if you shop based on cost it's not likely you would end up buying the thicker circuit board stuff (as weighter stuff is more expensive).
The iron transfer worked awesome. This valentines day my wife gets a hand-made card which could be framed. :-)
If you are etching, you only have 2 "colors": copper and substrate. There is no ability to blend or gradient the colors except by dithering/halftones. So you must use black and white, for best effect.
Also note with B&W, there are a range of dithering and halftone options you can choose from, which affect both the coarseness of the dots (think: newspaper halftones) and the placement of the dots (in a regular grid, or gridless which makes the dots look more randomly placed, like old Macintosh artwork).
As a constructive suggestion, @syrax's b&w photo looks a little washed out in the highlights. That's not due to his b&w method, but rather the original photo -is- actually washed out in the foreground. This could be fixed by playing around with the Levels or Gamma in Gimp or Photoshop, and that would restore some facial detail that's currently lost in a large area free of any detail (white).
I'm about to attempt this, to take up extra space on a PCB, for my first etch. :-)
It looks like an old sink that we had in our farms here way back then …
Am I wrong ?
Note, for the funny side ot things : at 1st I thought they were resting on the curb of a side walk. Curbs in most French cities (from where I post) are made from the same stone, with water runnig at the base it made the whole thing real. But who would put apples there ???… :D
As an Art Major (who is planning on going to medical school, completely abandoning art for the time being), I focused on printmaking.
To clean the plate without damaging it (steel wool seems harsh) I always used cheesecloth with a bit of mineral spirits. It works really well if you are using lithograph inks.
Also, you can find genuine copper plates at art supply stores. They are expensive! In fact, I split the cost of one with 3 classmates during my last semester of college (Spring 08) and haven't used it yet. Fear of commitment/not wanting to ruin something so expensive led me to re-use the plates people had discarded, even when no copper was left.
I've started doing a few printed circuit boards and been having some problems, but there's ideas in here that have helped.
Stu
no laser transferring for me
The Real Elliot has made an instructable on a gud alternative.
