Easy Ice Ball
13,240
41
9
Posted in TechnologyScience
Introduction: Easy Ice Ball
I wanted a ice ball maker after having one of the ice spheres that it makes put into my drink i loved it considering how long it last so i went online to price them they are way too expensive for my blood so i came up with this and a very good outcome..enjoy
Step 1: What You Need
1. an exacto blade
2.ball pit ball...you can get a 100 pack of these at walmart for 28 bucks my daughter has hundereds so i used one of hers
3.water
4.freezer..of course.
Step 2: Next Step
take the ball and find the seem
Step 3: The Cut
now take your exacto and cut a small opening on the seem about 1 to 2 inches
should look something like this
Step 4: Adding the Water
grap the ball and squeeze where the cut is place it under the faucet and fill it up there will be a air bubble at the top dont worry about its no problem
Step 5: Freeze It
now put it in your freezer for like 5 hours and take it out
Step 6: Finish the Job
now that its frozen take your frozen ball and your exacto and start on the edge of your cut and finish cutting all round the seem and take your ice ball out
Step 7: Done!!!!!
the finished product is an ice ball with almost no flaw yes i did use tap water the reason it stays clear is because the air gets trapped and rises to area of the 2 inch cut..all you have is a little bubble on top clear ice ball with no cracks and no cloudyness hope you enjoyed the instructable please rate
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    9 Comments
    How do you reuse the ball put balls?
    I like this method!
    What I've learned from the comments:
    - boil the water before freezing
    What I've learned from my head:
    - drill a hole rather than cutting a slit in the ball to reduce air pocket
    What was the diameter of your ball pit balls? I found some that were 2.5" do you think that would be a good size? The glass I like to use is a 3" diameter cylinder.
    yea 2.5 should be good im not sure what size the one i used was cause i had so many different sizes and they where all mixed up i just picked one lol
    Clever! But, how do you do to obtain that crystal glass ice ball?
    When I ice, I get something white and almost opaque
    The opacity is caused by gas - i.e. dissolved-air.
    If you boil it, place it in an ultrasonic bath, repeatedly freeze-thaw, or purge it with helium... you can de-gas water and it freezes clearer.
    L
    they said why its clear in the last part, normally to get clear ice normally u boil the water 1st. there are probably a few methods out there that work just as well, like this one.
    OK, thanks Bongmaster.
