3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy Killswitch
Easy Killswitch
This killswitch is easy to make and only costs $9.27!
It can be uses on any thing that uses a 1/4 phone jack.
What a kill switch does for those who do not know is when pressed it kills the sound. the button on the top is a momentary on switch that when pushed reroutes the signal to the ground thus shutting off the sound for as long as you hold down the button. By pressing the butting rapidly you can create some cool studdering effects.
I'm going to show you two ways to make the killswitch. One way is just a killswitch and the other has a added rocker switch. If you record guitar or and thing else you can flip the rocker switch over(killing the noise)so there is complete silence well you wait for you part to come up then you can flip it off to bring the sound back. This makes it so when you are waiting there is not the sound of you hitting the strings or any thing else.
If any thing does not make sence to you feel free to PM me with a question.
Credit for the idea to make a kill switch goes to Super Cameraman though I did modify it a bit
Please leave a comment and rate my Instructable I like to know what need to be improved/changed.
Step 1Materals
Stuff You Need:
Drill with bits
Wire
Soldering iron
solder
2 1/4 audio jacks
a momentary switch(push to turn on)
some sort of box to hold it all
Stuff I Bought:
1/4" Stereo Panel-Mount Audio Jack (2-Pack) $3.99
SPST"soft-touch"momentary pushbutton switch $2.99
3x2x1" Project Enclosure $2.29
rocker switch(optionanal) $2.99
total #1 $9.97
total #2(with rocker) $12.96
100 comments
1-40 of 100next »
Apr 6, 2012. 11:01 AMecotech says:
I made one last nite,Before I saw this....Its the same W/O the rocker, but I used Command picture hanging strips to mount it on my guitar. That way I can remove the strip and not have to scrub adhesive if my guitar if I ever want to remove it.
Jan 17, 2012. 4:33 PMcolinmitchell says:
good post! will 1/4" Mono Jacks work? Any difference? Also, does it matter if the Mono Jacks are open or closed circuit??
Nov 27, 2011. 11:53 AMSkinr says:
What gauge wire should I use?
Feb 1, 2011. 11:24 AMpigeonpants says:
Fantastical! My bf's a guitarist, and for his bday my plan is to connect two homemade loopers (outlined in this instructable), each with their own on/offs, to your kill switch to overall make a two channel looper. I'm pretty excited about it (and the fact that it automatically means he's gunna have to step it up for my bday! ;D) and I'll report back if it's successful! Whee! =D
Feb 2, 2010. 3:58 PMizatrini4eva says:
 can i just twist instead of solder?..and any ideas on how 2 add 2 LEDs 2 the box..1 4 rocker and 1 4 button?????
Jan 12, 2011. 5:50 PMbiggunner says:
u cant add leds because there is no power to power them, unless u ran external power... but you could twist it, but its better to solder....
Jun 24, 2010. 6:02 PMSybr3nSchaaf says:
hey man, does the colour of the wire matter? are their differences in the wires? i'm a dummie, but i'm pretty good @ soldering, so the wires are the only thing i'm worried about! (btw i don't want comments like "you should let someone with knowledge do it for you!")
Dec 15, 2010. 9:00 PMhightekrednek2396 says:
color is personal preference and to keep track of what gets wired where
Nov 5, 2010. 2:26 PMdarkria 45 says:
the color of the wire does not matter at all.some wires have lots of small strands, and other have one thick peice, itl be best to use the stranded
Sep 3, 2010. 7:36 PMGlockenator says:
Wire color doesn't matter. It's all the same wire, it's just colored so you can easily keep track of which wire is which
Feb 23, 2010. 7:55 AMGlockenator says:
is this an actual Gibson/Epiphone SG or is it a copy?
Sep 22, 2010. 2:30 PMPropane Flair says:
looks like a '61 remake..
im getting a (gibson) SG standard for xmas and im buzzing already :DD
Jan 18, 2009. 9:57 AMoweng4000 says:
My Kill-switch buzzes allot. Does anyone have any idea why?
Jan 22, 2009. 5:17 PMoweng4000 says:
Fixed it wired it wrong!
Jan 26, 2010. 4:56 AMjoeooo says:
 same here! any ideas on what i did? i checked all the soldering it looks solid.. maybe i looked at the schematic wrong..
Mar 3, 2010. 9:10 AMoweng4000 says:
What happended to me was i wired one sides Sleeve(ground) to the other sides tip(the place that your guitar signal comes from). once reversed(sleeve to sleeve, tip to tip.)  the buzz goes away.
Feb 17, 2010. 3:27 PMflime1 says:
PLEASE SOMEONE HELP!!!! i made it and it works but there is a very annoying buzzing sound that happens when i plug it in. Is there a way to fix it
Nov 18, 2009. 9:49 PMTriworm says:
 does the switch have to be normally open, or normaly closed? please answer.
Feb 2, 2010. 3:57 PMizatrini4eva says:
 button is open
Jan 25, 2010. 4:53 PMxXMiNdFrEaKXx says:
Can you PM me a better diagram, I bought the same jacks as you but I have no idea on how to do this.
Dec 5, 2009. 5:19 PMGlockenator says:
if i did the switch wrong, would it potentially damge my guitar or amp?
Dec 5, 2009. 9:18 AMrubin69 says:
 ok so ive tried building it and im not sure how to wire it coz i bought an 1/4 audio jack and it has 3 loop things and one long thing so pls can you help
Nov 18, 2009. 5:45 PMGlockenator says:
heres the thing.how does this work when the souns not being passed through the wires in it?
Mar 11, 2009. 1:35 PMBradlez92 says:
what is the "rocker" switch called in real life, so we're all clear :S?
Nov 16, 2009. 3:05 PMGlockenator says:
its just rocker switch.no fancy name
Mar 11, 2009. 1:50 PMBradlez92 says:
nevermind :P although, do you think a lighted momentary and rocker switch would work aswell? or would you need some sort of power source?
Nov 18, 2009. 5:46 PMGlockenator says:
i think you would need something has a power supply,but there would be power from the amp so you never know
Nov 18, 2009. 8:55 PMBradlez92 says:
I'm not as sure though... I mean, there HAS to be some sort of power source. Otherwise we wouldn't have to power other guitar pedals externally, no?
I'd  test it out myself, but I have neither the time or equipment, nor the wild abandon to throw around money to test on electrical trial and error junk in a "what-the-hell-am-i-doing" haze =D.
Nov 16, 2009. 3:04 PMGlockenator says:
do you need a normally closed switch or a normaly open switch?
Jul 22, 2009. 6:43 PMguitardude12317 says:
is there any way you can make it (the killswitch) into a pedal?? i saw it plugged in on your pedalboard and i was just wondering...
Sep 16, 2009. 3:24 PMtoogers says:
just get a bigger button, and use as pedal.
Aug 24, 2009. 7:30 AMmchs60chip says:
interesting i'll have to try this btw i have that exact same distortion pedal for my guitar
Feb 14, 2009. 1:48 PMcouch style says:
hiya, i like the guide, i went out one day and tried to attempt it myself, however when i plugged mine in, no or little noise came from the imput end, however both the momentary/ toggle switches are working well. What have i done wrong with connecting the two jacks so that sound would transfer properly? thank you.
Aug 19, 2009. 3:30 PMcdousley says:
make sure its properly grounded
Jun 17, 2009. 6:46 PMCyberCrash says:
If u got a 2 vol. knobs guitar,wouldn't it be easyer to u to just leave a know at the minimum and turn the key?
May 12, 2009. 5:13 AMblink182folife says:
i'm looking at your schematic and i'm a little confused. if the buttons or in parallel, how are they supposed to kill the sound? i tried it out anyway and sound comes out but neither of the buttons kill the sound. even when i tried wiring them in series it didn't work. any suggestions?
May 25, 2009. 9:25 AMblink182folife says:
never mind, it works perfectly! great guide!
1-40 of 100next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:somerockenguy
