Easy Knex Tank
Introduction: Easy Knex Tank
easy to build knex tank
Step 1: Motor Axle
its easy if you follow the picture.
Step 2: Rear of Tank
the picture is your step.
Step 3: Front
i oopsed here but in the next pic or two it will fix itself.
Step 4: The Chassis
this will hold the motor up off the ground.
Step 5: Attaching the Chassis
its really easy.
Step 6: The Front Is Assembled
this is a bit tricky in the front the chassis support beam is where the two way connector is the order is different just follow the pictures.
Step 7: The Track
just look at the picture
Step 8: The Finished Tank
just connect the track and your done.
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    some1 should make like a giant tank that can support a person and has controls...all you woul;d need is
    -a whole **** lot of knex
    -some super glue, to make sure it not break
    -a bis @$$ motor
    -and some more knex
    and maybe a big rubberband
    good idea, but u need a lot of wheels, u will have to put wheels every 2 or 3 inches again so the tank doesn't breaks .
    ill get to work that thank for the idea :)
    I use stronger treds made with white tubes and small grey parts, always 1 light part in the middle and 2 dark parts left and right of it, when u attach 2 wheels on each side of a motor ( leaving an opening between the weels ) the treds will have a lot of grip and won't slide away !
    first comment! haven't got one of those for a while. looks good but I'm sure you could make it better.
    not that it has any thing to do with it but...........................like the name
    nice but a little small I give you a 3/5 p.s.:bunny!!! (\_/) (0.0) (> <)
    no sir bunny ()() (.,.) (,(,)
    yay now I have 2 bunnies !
