easy longlasting firestarter
 by poiu12340
This fire starter is so easy and last a long time. Great for camping.
Step 1: Tools
You will need steel wool and a 9volt battery That it.
kdf.inc1969 says: Sep 25, 2012. 5:42 PM
do you have to use the whole steel wool or can you section it up?
kdf.inc1969 says: Sep 25, 2012. 5:39 PM
i was looking for an easier way to start camp fires. thanks for the instructable
battle says: Jan 21, 2012. 11:24 AM
how long does it take for the steel wool to light
computerfaker3 says: Dec 9, 2008. 8:40 PM
wow quote DANGEROUS! IT COULD START A FIRE ha ha nice
battle in reply to computerfaker3Jan 20, 2012. 3:09 PM
good joke
heyzuphowsitgoin says: Jun 27, 2008. 5:44 AM
DANGEROUS! IT COULD START A FIRE :D nice job i never woulda thought steel wool would heat up from a 9 volt battery!
Derin in reply to heyzuphowsitgoinJul 1, 2008. 8:35 AM
thats what this thing is for-starting fires!
heyzuphowsitgoin in reply to DerinJul 1, 2008. 9:31 AM
yes i no i was joking
battle in reply to heyzuphowsitgoinJan 20, 2012. 3:08 PM
you usd the wrong type of no. its know
Derin in reply to heyzuphowsitgoinJul 1, 2008. 9:43 AM
oh ok
Derin in reply to DerinJul 17, 2008. 11:56 AM
here is the bottom line :P
Rebelchief says: Apr 30, 2009. 6:21 AM
just in case someone doesn't know....the steel wool is causing a direct short on the battery terminals. this causes sparks, starting a fire. while this won't cause a "shock" to the user, it will cause burns to the fingers/hands.
cornflaker in reply to RebelchiefJul 13, 2011. 2:55 AM
... I did this many times when i was younger and never burnt myself, it just takes a little common sense (e.g. don't touch the steel wool when its hot. I mean you don't go holding your fingers in the flame of your lighter while your trying to start a fire do you?)
Electronics Man says: Jun 23, 2011. 3:05 PM
I definatly agree with bajablue A blowtorch is always best but I have used this method to start fires and it works great
bajablue says: Jun 18, 2011. 1:47 PM
Sorry... the easiest, BEST way to start a fire is by using a handheld propane blow torch...( just sayin'.) but this is truly GREAT!
bajablue says: Jun 18, 2011. 1:44 PM
Wow! This is like watching a McGuyver rerun. LOVE IT!!!!!!
.Hexx. says: Feb 21, 2011. 4:06 AM
Isn't this a dangerous procedure?
Schpool in reply to .Hexx.Mar 3, 2011. 7:13 PM
Only in the fact that when steel wool burns it poduces a poisonous gas that is harmful when inhaled. so as a precaution it is best to try to avoid the smoke that rises off of it.
ArcticLiz says: Sep 17, 2010. 7:51 PM
Is it necessary to blow on it??
computerfaker3 says: Dec 10, 2008. 2:06 PM
what else can a 9volt battery start on fire?
adam 101 in reply to computerfaker3Apr 16, 2010. 3:45 PM
it will start a pencil on fire. sharpen both ends of a wood pencil and wire the graphite (pencil lead) to the battery. It may take a little while but it will get very hot!
bustedit says: Aug 20, 2008. 9:02 AM
does the 9v have to be new/fully charged? and how many times can the battery be used? thanks for the tip!
poiu12340 (author) in reply to busteditAug 20, 2008. 2:35 PM
I think it works with old batteries It depends how old it is. it should work about I have done 5 times with 1 battery but it should work more than that. another thing is that it works better on some types of steel wool.
imthatguy1125 in reply to poiu12340Apr 10, 2010. 5:49 PM
 ive used one about 20 and it is still working
henrywfstone in reply to poiu12340Oct 6, 2008. 10:38 AM
the newer the battery the better... it heats up the steel wool and it can set dry grass or other tinder alight. not great for camping as it doesn't work well when wet.
cornflaker in reply to henrywfstoneDec 11, 2008. 11:58 PM
But it does still work. Normal matches, and using friction methods won't work when wet, and it also doesn't need the sun like a magnifying glass or reflector.
Faquad in reply to cornflakerJul 12, 2011. 10:41 PM
you can also ignite it with a "metal match" method (google Metal Match if you want more info)
joe999999 says: Jan 6, 2009. 9:11 AM
How long does the starter last? Does it depend on the amount of steel wool and/or the volts of the battery. And thanks for your post. I will no longer need to ask my husband to pleaassee start a fire!!
poiu12340 (author) in reply to joe999999Jan 6, 2009. 3:57 PM
It depends on the amount of steel wool not because of volt. But you need 9 volt battery because it is easy to start it with that. only fine steel wool will work. most will work but sometimes you will find some that doesn't work.
alfpwns says: Aug 4, 2008. 5:34 PM
where u get steel woll?
Thelonelysandwitch in reply to alfpwnsDec 29, 2008. 9:05 AM
everywhere, Brillo pads will also work, the finer the better.
poiu12340 (author) in reply to alfpwnsAug 5, 2008. 6:14 AM
You can get it at target, homedepot, Ace hardware
finnster says: Nov 4, 2008. 5:35 AM
2 D cells will actually catch it on fire (big bubba's dad showed me)
wiebevandomburg.hotmail.com says: Oct 30, 2008. 6:23 AM
you can use any battery above 4.5 v and it lasts more then 20 times , i used it to light fireworks , after 20 pieces we had to stop , not because the battery died , but there were no more fireworks
SKINZ says: Sep 24, 2008. 4:41 AM
cool im guna tell ray mers so he dont need to keep rubing sticks together lol
LinuxH4x0r says: Jun 28, 2008. 9:38 AM
I do this all the time!
mastercreator says: Jun 28, 2008. 8:54 AM
cool i didnt know you could do that
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
