Easy Air Powered Hydroponic System
Published
Introduction: Easy Air Powered Hydroponic System
this is my hydroponic system that is really easy to make because it has no pump. the system delivers water to the plant by using air to force water up the piping to the plant them drains back into the water tank.
Step 1: Materials You Will Need
1.a glass jar
2.a plastic pop bottle.
3.aquarium air pump
4.small plastic tubing
5.medium plastic tubing
6.grow medium/ vermiculite, hydro-ton or the equivalent
Step 2:
cut the bottle in half
Step 3:
cut a hole in the cap of the bottle big enough to fit the medium tubing in it snugly.
Step 4:
put the small tubing in the medium tube
Step 5:
add water to the glass jar and put your top half into the jar add your grow medium make sure the grow medium covers the top of the tubing to prevent  water from spraying out the top
Step 6:
add your plant
Step 7:
now put your planter in a nice sunny place and plug in your aquarium air pump and add your nutrients to the water and let it grow.
Step 8:
I started the system with a small pepper plant and after a month the plant took off and now is big and has flowers
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    4 Discussions
    Pepper plant is starting to flower
    So far my pepper is growing great it's about 6 inches talk and 5 inch wide
    What I mean by no pump is that it has no water pump that needs to bee mounted on the inside. And a air pump is not the same as the one for what all it is used for is to add air into the system to bubble the water up the tubing to the plant
    You call your instructable "Easy no pump hydroponic system". Isn't an air pump a "Pump"?
