Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
I have plastic wrap questions. I have kale seeds that sprouted a few days ago. They're not ready to go outside (I have been told four true leaves, and these guys only have their cotyledons so far), but they are getting pretty tall. I'm afraid that if I leave the plastic wrap on, I'll (a) crush them (I could make a contraption to handle that) and/or (b) suffocate them (it's not airtight, more just draped, but it does prevent much airflow and/or (c) cause them to mold in there. Thoughts? Suggestions?
For reference, I live in coastal, southern BC. It's permanently soggy here, hence the mold concern. We're past frost, but it's still very cold at night.
Yes, IF the egg container material is PAPER based, but not the plastic foam, it is perfectly acceptable to plant the egg carton "cup" with your seedling BUT...
the spacing between plants in the "paper mache" type egg cartons is TOO CLOSE TOGETHER for proper plant spacing once in the garden.
So what I do is, when the seedlings are ready to plant in the garden, I use sissors to cut the "cups" of the egg carton APART, and then plant the cups WITH the contained seedlings at the spacing distance recommended on the seed packet.
IMPORTANT: For this to work, the egg carton cannot be plastic foam, but must be the paper mache type made from ground up paper. Usually you can identify this as the plastic or paper/cardboard material are clearly identifible by looking at them. Also usually, the paper type is a grey color, while the plastic ones are usually bright colors, and shiny surfaced.
Also did one slight thing too of using top of egg carton as a seed tray for smaller seeds like lettuce.
These corn plants you've got look like they're off to a great start. Kudos!
omg corn rocks!
