3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
easy seed starter.
easy seed starter.
a simple, cheap way to get some seed started before getting them into the garden.
Step 1Materials.
materials.
egg carton, any size.
soil.
scissors.
seeds.
plastic wrap.
time.
57 comments
1-40 of 57next »
Apr 27, 2011. 2:20 AMjwoo2023 says:
THAT EGG CARTON IS HUGE! In Australia they sell them in packs of 12
May 15, 2011. 1:27 PMpadawanspider says:
Mostly they're sold by the dozen in the U.S.A. too, but one can frequently find 18-packs (and 3- and 5- dozen packages in certain stores).
Apr 10, 2011. 7:30 AMvelacreations says:
Why don't you try it without the container? Soil Blocks are easy and work really well: http://www.instructables.com/id/Make-Super-Cheap-Seed-Starters/
Jul 19, 2010. 6:55 AMhappyfmly3 says:
Take any portion of your eggcarton mix it in the blender dry it out and sprinkle it into the garden the worms love to eat cardboard broken down to their capacity to ingest it. Want to give the worms a real treat take your grass clippings and your egg carton put that in a blender dry it out mix it with a little soil and now you have great worm food or simply use the mix as a soft potting soil. Plants love to grow in this mixture soil is rejuvinated. After drying re-blend one more time dry and your mixture looks like peat moss and ready to use. Last step: (to keep your wife from harming you) go and buy her a new blender, keep the compost blender for your self.
Mar 27, 2009. 6:46 PMtillmancan says:
Does this mean that you just stick the new plants carton and all right into your garden?? I'm a new gardener and am looking to grow veggies w/my kids this year in an urban planter box in our back yard....I'd hate to get this far with the seeds just to kill them in the ground because I didn't take them out of the carton! (I'm so sorry if this is a stupid question!)
Apr 25, 2010. 2:32 PMjohnny3h says:
This is a little late for tillmancan, but can benefit others reading after this posting.
Yes, IF the egg container material is PAPER based, but not the plastic foam, it is perfectly acceptable to plant the egg carton "cup" with your seedling BUT...
the spacing between plants in the "paper mache" type egg cartons is TOO CLOSE TOGETHER for proper plant spacing once in the garden.
So what I do is, when the seedlings are ready to plant in the garden, I use sissors to cut the "cups" of the egg carton APART, and then plant the cups WITH the contained seedlings at the spacing distance recommended on the seed packet.
IMPORTANT: For this to work, the egg carton cannot be plastic foam, but must be the paper mache type made from ground up paper.  Usually you can identify this as the plastic or paper/cardboard material are clearly identifible by looking at them.  Also usually, the paper type is a grey color, while the plastic ones are usually bright colors, and shiny surfaced.
Mar 28, 2010. 8:26 PMNinjaJay says:
 I did this egg-carton seed tray recently, before seeing your instructable, and will also plant it all directly in the ground, but wanted to offer that probably not all plants will be strong enough that their roots will be able to push right through the form.  I pre-pricked the bottom of the cones before sowing seeds in.
Also did one slight thing too of using top of egg carton as a seed tray for smaller seeds like lettuce.
These corn plants you've got look like they're off to a great start.  Kudos!
May 9, 2008. 11:26 AMwebcompanion says:
You could throw the top portion into a compost pile and recycle it that way.
Mar 20, 2010. 3:51 PMenuwbe says:
 Make a compost tumbler, they work faster.  Use an old trash can, or if you can get a hold of a 55 gallon barrel they work like a charm! You can build one, or just put it on its side and roll it around once a day. So much fun!
Feb 15, 2010. 6:25 PMsuezq says:
Egg cartons are great for starting seeds and I even use avacado skins after the insides are scraped clean. They make great little bowls that break down once they're buried and feed your new little plants.
Jul 8, 2009. 8:58 PMjessfelfoldi says:
Great idea! I am trying this out with some loosely wrapped plastic wrap to get a greenhouse effect. Hopefully I will have photos of shoots to share soon. As a bonus, after I stuck my markers in, my carton looks kind of like a ship.
Nov 16, 2009. 4:18 PMdrronnyallard says:
can I ask how this worked for ya? I'm trying to do a green house, and just not too much to work with...
Nov 16, 2009. 5:25 PMjessfelfoldi says:
It worked pretty well, but since it was kind of humid when I was doing this I had to be really careful not to over water or my little cups would get waterlogged.  I've seen some really great instructables on here using plastic takeout cartons that seemed pretty good if you have more seedlings to get started.  Good luck!
Nov 16, 2009. 7:31 PMdrronnyallard says:
I plan on doing it with a few clear, plastic boxes you can find produce and grapes in (grocery stores)... all I've read about doing that on here has seemed good. ...but hey, all I can do is try. I'm in zone 4, but I usually try to start my plants in Febuary, under grow-lights. Thanks for your comments!
Nov 16, 2009. 5:31 PMsteampunk-punk says:
omg corn rocks!
Apr 2, 2009. 9:39 AMlordzion says:
ravinC83 worte if you live in the city you might want to check the chlorine content in your water. if the levels are high you might want to get some distilled water. If you live in the city most likely your water contains chlorine to get eliminate this just place the water in a container and in a couple of days the chlorine will evaporate and your plant including house plants will love this
May 30, 2009. 3:48 PMjdtwelve12 says:
Or keep an aquarium and use the waste water from the fish tank to water your plants. You'll already have taken care of chlorine and/or chloramine in the tap water before putting it into the tank. The water you take out of your fish tank when doing weekly maintenance is great for plants! Plenty of nitrites and nitrates in there. Free plant food!
Jun 20, 2009. 6:05 PMawang8 says:
I don't think too much salt would be good for the plants...
Sep 25, 2009. 9:50 AMjdtwelve12 says:
Sorry, I'm talking about a freshwater aquarium. Yes, salt water is not good for your plants, but if you keep goldfish, guppies, mollies, swordtails, plecos, danios, tetras, etc, the waste water is very good for your plants.
Jul 26, 2009. 7:26 PMdventu says:
I will try that i don't think it would work
Jul 9, 2009. 1:04 PMwazure says:
add the lid a little beanth your planted sprouts within your raised bed (if you are using a raised bed), it will biodegrade into the soil and the folds/creases/corners of the lid will provide space for microbials to grow, which will greatly enhance your soil. look up "lasana layer mulching", to have more detail explained.
Jul 9, 2009. 12:59 PMwazure says:
Orchard Supply and Hardware
May 14, 2009. 10:42 AMvee77 says:
Great instructable, this is actually how I started squash and sunflowers this year. It makes transplanting easy. For greenhousing started seedlings, the first few days I put a papertowel over it and wet the paper towel every morning and put it in plastic. Then sat it in the sun. Then I removed the paper towel and kept it in the plastic for a little bit. One thing that has to be paid attention to though is mold.
Apr 13, 2009. 6:11 PMmagnoliasouth says:
This works great in most zones, but not ALL. I used to live in Alaska and you can't plant the egg crate there. They don't degrade in cooler soils. I just note this because Alaska has a lot of military there and they come from all over the US. They won't be aware of the local dos and donts. This is a don't for some and they need to check before doing it. Just a tip! I was a southern gardener in the arctic and it was WAY different than I was used to.
Apr 4, 2009. 7:05 AMcaverron says:
This works great. I also set them on a piece of insulating silver wall board for heat retention. Then use a clear plastic sweater storage box to cover them. This holds about 5 egg cartons ( cut to just the egg cup side). This holds the humidity and heat. Perfect little greenhouse that fits nicely on a shelf or table by a window. I also use plant bulb in a desk lamp for light.
Mar 18, 2009. 6:26 AMgrannycat07 says:
I do same as "khaotik" putting lid under without plastic for better absorption, on tray on windowsill, AND use top or bottom of clear plastic egg carton to cover, for greenhouse effect: gets 'em started quickly!
Mar 17, 2009. 8:24 PMlauriedemers says:
I use this method!! love it learned from my mom. I find the planting mix floats, so I rinse with a stainer, wet it down. then use a small ice cream scoop to fill it.
Mar 16, 2009. 11:42 AMkhaotik says:
I did this and it worked well. I didn't line the top with plastic, just placed the egg carton in the lid to make the whole thing more sturdy. It absorbed water and helped keep the soil from drying between waterings. When I transplanted it was easy to tear the cells off the carton, and I chose to remove paper on some of the seedlings depending on the roots. With peas - the roots grew right through! Now I am doing it with the eggshell halves placed back in the carton. I poked a hole in the bottom of each eggshell to let it drain into the paper. When its time to transplant I can just pluck each eggshell out of the carton, give it a little squeeze to crush it, and plop in in the ground. Now that's biodegradable!
Feb 26, 2009. 7:09 PMdabido says:
when transplanting the sprouts to larger pots, should you just cut each cell and plant the carton with the plant into new soil? or ditch the carton when transplanting?
Mar 4, 2009. 1:43 AMawang8 says:
I think cutting out each cell will allow you to plant the plants further away so they don't die of squishdom (homemade words are awesome).
Jun 20, 2009. 6:07 PMawang8 says:
It won't biodegrade fast enough and then masses of roots start to stick out of the carton and the plant becomes weak because there is still loads of roots inside the cells and then when you break open the cells the roots get chopped off and then your plant will hate you. Or at least that's what happened when I tried this last time with tomatoes... (I think I left them in there too long. It says 14 days on the packet... I left it there for about a month... Oops...)
Nov 29, 2008. 9:45 PMcfishy says:
I think you should explain what osh stands for. It's a home and hardware center. It's not in every state, so people might not know what you are talking about.
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:ravenc83
