Easy Tile Necklace
6,079
76
28
Posted
Introduction: Easy Tile Necklace
Dremel Jewelry Contest
Finalist in the
Have you ever noticed the beautiful mosaic tiles in the flooring department of the hardware store?  I think they are enchanting.  So why not make a necklace out of them?
Step 1: Materials and Tools
There's nothing new going on here.  Just some really basic metal forming, attaching some glue and findings.
But here are all the things you might want to use
files for smoothing rough edges
tin snips for crudely cutting metal
jeweler's saw for finer detailed cutting of metal
pliers for bending metal
findings such as chain, clasps, jump rings, etc.
a torch for heating up metal to make it softer
a pan of water for cooling metal
glass mosaic tiles
sheet metal from the hardware store.  I used a 6" by 24" sheet which was $5.  26 gauge
Step 2: Create a Pendant Bail
or you could just go buy one if you prefer.  I didn't have one around, so I made a crude one out of sheet steel
Heat up the sheet metal with a torch until it turns red and starts to change colors.  This will soften it and make it easier to cut.
Dip the hot metal in a pan of water to cool it off.  You will hear it sizzle.  After the  hot areas are submerged in water they will be cool and easy to handle.
Snip out a little strip of metal with the tin snips and file the rough edges down with a file
Step 3: A Different Bail
Try making a fancier bail if you feel like it.
Trace a design into the softened metal.  Cut it out with the jeweler's saw.  File the edges and finish however you like.
Bend it to fit the piece.  Glue into place
Step 4: Glue the Bail to the Tile
I don't know quite what glue to use for this.  I'm just trying this stuff shown for the first time.  Super glue might work just as well.
Be careful with the glue.  Try to keep it off your fingers and off the face of the tile.
Step 5: Attach a Chain
Select a chain, cut it to the desired length, thread it through, attach jump rings and a clasp... just the basic stuff
Race you to the swap meet!  woot!  =)
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
  • Gluten Free Challenge
28 Comments
E6000 is the type of glue to use for the bail. It's available at any craft store, or online.
This would be a great way to make pendants out of sea glass! I like the way you did the bail - looks nice and clean. I wouldn't recommend 'super glue' because it doesn't stick well for glass long-term. Tends to come undone after a few days.
Nice, I think I have some tiles like that lying around, great idea turning them into a necklace.
Here is mine, I used a store bought bail (metal work is not my thing). I love it, thanks for the great 'ible!
ooh beautiful!
cool, thx!
I wonder if you could just use a dremmal (sp?) and cut a hole in the top and then add some twisted wire to make a bale...or or or, maybe wrap it around the tile and so on... hey I just got an idea...thanks for the instructable. These are very pretty.
Yeah I did try to drill a hole at first, but couldn't get anywhere with the drill. But maybe with the right drill bit it could work.
probably, I used a diamond tipped one to put a small hole in a piece of sea glass, submerging it in a very shallow bowl with a little bit of water in it to keep it from braking, than fed a silver wire thru and curled it around the front and twisted the top with some glass beads and made a very pretty charm. It's about an inch and a half long and haven't found the right chain for it yet. I might just make one to go with it cause it's in my bead box with like 30 or so more of different charms. I like making them but never put them on chains...lol (I'm weird.) One day I'll make a tut on how I do it, but there's so many of them as it is.
A diamond tipped drill bit sounds like a great idea. I'm going to have to look for one.
