3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
easy tinder
easy tinder
this easy tinder will catch sparks, is easy to light, and will burn for a long time.
Step 1Purchase
purchase
go to walmart and by some fire sticks, they're about2$ for a bag of twelve
30 comments
Dec 10, 2009. 5:54 AMcharleschiu1996 says:
Yeah i know they're like so clear
May 21, 2007. 7:17 AMKiteman says:
Why does this Instructable need to be done in the dark?
Nov 23, 2009. 12:07 PMsharlston says:
because flames are better in the dark and i dont think the auther is a pro photographer
Dec 22, 2008. 2:18 AMawang8 says:
I'm ten and I'm a pyro... This morning I was out there trying to burn leaves... Now my pants smell like tobacco.
Oct 9, 2008. 2:07 PMtrampart says:
Nice pics
Sep 1, 2007. 12:14 PMthemasterpyro says:
ne ideas were i can get some largeish flint chunks? ANY good links to sites were i can get largeish flint chunks are welcome.
Aug 5, 2008. 8:59 AMFunkNattidelic says:
a lighter with no more gas left will work i believe.
Jun 6, 2008. 2:23 AMDigital_Anarchy says:
fire steels are not made of flint, they are ferrocerium, an alloy. also when starting a fire with real flint you strike the steel with the flint, not the other way round.
Sep 3, 2007. 7:19 PMthemasterpyro says:
oh i ment flint as in the stone. you know, flint spear head?
Jan 15, 2008. 4:56 PMbigcheeze says:
this ones kinda hard butt you could mix it with a pinch of saltpeter/kno3 (maby it'd end up like flash powder or somthin)
Jun 17, 2008. 2:04 PMTheMadScientist says:
and where might I ask are you going to get potassium nitrate, other than from fertalizer...
Jun 17, 2008. 3:33 PMbigcheeze says:
grants brand stump remover,or spectricide grants is 98% pure spectrecide is 99% and comes finly powdered,the grants you will have to mash it in a morter and pestle
Apr 12, 2008. 10:52 PMfunwithfire325 says:
The very first picture in the intro looks like a burrito.
Aug 15, 2007. 12:33 AMellomate56 says:
Good idea but why not just use the sticks? Also, you could put in some foil and put a fuse in (mix the tinder with a little lighter fluid). I don't know what it would do but, it would do something. Or mix the tinder with cotten. It would burn longer too. Or wood, ha.
Aug 16, 2007. 3:28 PMellomate56 says:
Well, I ment put it inside like a ball of foil but it would be the same thing... but what about the cotton? Wouldn't that work?
Jun 2, 2007. 12:30 AM5150Mike says:
Even better, and Cheaper... Dryer Lint. That fuzz that gets trapped in your dryer that everyone throws away... Its actually very flammable and burns slow enough to catch your tinder.
May 20, 2007. 10:28 PMLasVegas says:
And this is better than the Fire Sticks... because?
May 20, 2007. 10:55 PMSgt.Waffles says:
Because its crushed up fire sticks!!!! lmao. To make a decent fire starter. but a pine con in an empty tuna can, and fill the rest with parifin wax. Or if you are a fellow survivalist, you could use stuff from your surroundings, ie bark, grasses, june bugs.
May 21, 2007. 7:18 AMJohn Smith says:
What about june bugs?
May 21, 2007. 7:43 PMSgt.Waffles says:
They make good fire starters.
May 22, 2007. 10:38 PMhowboutitbru says:
i personally prefer mayflies, they crackle sometimes. we should discuss insect fire starters!
May 21, 2007. 12:20 AMmeddler says:
This really isn't that bad if you like using flint and steel and don't wanna make your own char cloth. Tinder moss works just as well.If i want a good fire starter i rub petroleum jelly into a cotton ball, pull some fibres out on one end and light with a quick flame from a cheap lighter. They will burn nice and hot for a few minutes, plenty to start a fire. My friend keeps them in a plastic baggie in an altoids tin when he is hunting.
May 20, 2007. 9:17 PMGmastefluffy says:
wow man , if this isn't the pinnacle of instructables then i don't know what is. But seriously. be much more descriptive and precise with instructions, intensions, and if you have to use a bad camera, at least have good lighting.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pyro13
I like girls, fire, and hangin' with my friends
