Emergency Battery Light
1,130
11
Posted
Introduction: Emergency Battery Light
in this instructable i will show you how to make a emergency light with parts easily found in the house powered by a 9v battery helps in power faliure a lot
Step 1: Find the Items
u will need:
a 3 led bulb (can be found any where broken can be used)
a 9v battery
2x wires
a switch
a 9v connector
Step 2: Open It Up
take the bulb and tear it up you need the flashes and its magnifiers
i used a broken bulb
Step 3: Power Is the Key
take the connector+wires solder them make connector and connect to the battery now connect one wire to the wire and join it to the battery dont join the second one
Step 4: At the Power of a Switch!
take a switch and connect the wires tightly now decorate it how ever u prefer i took a small pringels container so changing the battery is easy and the switch is stiff! dont forget the magnifiners they will enhance the light
best of luck and thanx for viewing it :)
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
2 Comments
Recommend at least a 150 ohm resistor in series between the battery and the LEDs as some LEDs will burn out by running directly from a 9V battery.
no it will not burn probably because the LEDs are used in a bulb and it can resist even the voltage of direct electricity supply but you can use a resistor if you want to
thanx for feedback:)
