3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
emergency vehicle escape keychain
Step 7Drill keychain hole
drill keychain hole
After sanding allow the epoxy to completely set (maybe an hour, maybe overnight depending on the type of epoxy used), then you can start drilling the hole to hang your belt cutter from your key chain.
You will need to use a drill with a bit specifically designed for metal, if you use a wood bit you run the risk of damage to your tools, this project, and yourself. Slap on your safety goggles and slowly start drilling.
The reason we're using a metal bit is because we're going to drill through the metal blade inside. Start small with a pilot hole, then change to a large bit and drill again to enlarge the opening.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
761
Author:mikeasaurus(michaelsaurus.com)
I'm the Play Editor here at Instructables! I like mixing old ideas with new and reusing things not for their intended purpose; the results are sometimes messy but always fun. I also write the thrift-...
more »
