Enhance Your Car or Ups Battery
2,680
25
13
Published
Introduction: Enhance Your Car or Ups Battery
About: cheap and easy tricks
today i will show you how to enhance a battery ressults of the improvement can be seen within a week or 2
you will need
epsom salt (magnesium sulphate)
distilled water
Step 1: Gather It Up
a battery with six caps or cells needs
2 cups of epsom salt
2 cups of water (distilled water preferd)
now take them in a boul or bin
Step 2: Heat It Up!
heat the mixture under stove keep heating till it is dissolved properly and forms a yellowish mixture
the mixture is (MgSO4/H2O)
Step 3: Fill the Tonic!
take the battery and the mixture remove some battery water so we can fill our tonic fill same amount of it in each cell
best of luck!
WARNING!
dont taste the epsom salt it is a salt but tastes very bad otherwise its unharmful
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    13 Comments
    So how well did this work... I'd like to see before and after Voltage/capacity tests and voltage with a load!
    New Battery is only 20 $ 12 v 7 amps i think you can earn more money doing something elese
    you have to keep adding water to the battery like you normaly do and it will be active
    I'm sorry but 2 years? The sulfates added will condense during discharge and are more likely to cause shorts between the plates in the cells. Additionally now the ability to drive them back into the solution (electrolyte) during an equalization charge becomes impossible. Chemistry does not lie. Even adding more sulfuric acid to a lead acid battery will shorten its life.
    Mostly sealed car batteries here too in Canada. they CAN be opened, but requires a bit of work.
    yeah its for batteries with cell caps
    this may help
    https://www.instructables.com/id/Refilling-SLAs-Sealed-Lead-Acid-battery/
    nowadays, I only see sealed batteries in UPSes and car batteries, nothing to fill. at least here in the Netherlands that is.
    these batteris dont need water they are in gel state but the one that opens needs water
    and those battries cannot be repaired at home
    Enhance in what way?
    If you provide some links, info and so on,
    People might take it more serious.
    Just a sugestion :-)
    if your battery is dead you can give it a new 2 year life
