Ergonomic Table
19,063
258
23
Posted in WorkshopWoodworking
Introduction: Ergonomic Table
About: DIY is my hobby
I always use my laptop in bed.
Using the laptop in bed is very difficult without the appropriate table. Given that I'm living in iran and global markets are not available. Table if there is such a price is too expensive, I decided to make it myself.
Hopefully, the description is understandable given that they do not speak good English.
Step 1: Ingredients
1.The MDF board used
2.Computer box cover
3.Metal bolts and washers
Step 2: Leg
Each piece 25 cm
It depends on the size of your laptop.
Step 3: Cutting Metal Sheet
24 pieces of sheet metal are removed by Angle grinder.
To prevent the wood from wear robes.
Step 4: Metal Pieces Glued to the Legs Table
A piece of metal with wood glue to glue the two ends
Step 5: Drilling
By drilling two holes in the wood to bolt diameter
Step 6: Sheet Metal Bending
Sheet metal for the floor to create a table as picture
Step 7: Install Sheet Metal
Two small pieces of wood that were already prepared to make a floor plate
Step 8: Painting and Assembled
In this step, you can paint any color you want your table and connect it to look like the picture.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    23 Comments
    How did you get the joints to hold the laptop? I made one using the same design except with all wood. However, the wingnut and screw are not strong enough at all.
    I made another one in pine wood and mdf a year ago inspired in the same concept. Simpler than these and, obviously, cheaper (about $8)
    Strength and Beauty
    Yes sure is portable.
    It weighs 1.5k kg.
    The assembled dimensions 35 * 25 * 1.5 cm.
    I've been looking for a good laptop stand (or any table like that in particular) its been the best one I've found! Definitely looking forward to build one over the summer:)
    I am very glad that I made ​​was the best one for you.
    Do not forget me if you need help.
    Thank you very much.
    my, you must have a lot of patience to cut all those bits of sheet metal. wow.
    Being patient is the key to creating good thing.
    thank you....
    thank you very much
    thank you jade o gator
    Love it, good job :)
