3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
etched neon light
etched neon light
this project is pretty easy I did it in a total of 2.5 hours (including etching) the list of things needed is
a neon for pc or a car light
about 1.5' of pvc
plexi glass
12v adapter
the tools needed are:
dremel
hot glue gun
radial arm saw
stationary sander
and a computer
Step 1Designs
designs
go on the internet and look up designs relatively easy design such as steal your face, the mortal kombat logo, thundercats logo,and the instructables robot. I stole mine and changed it to black and white using photoshop 15 or adobe. make sure the design is backwards. after that print it out and tap it on one side of the plexi glass make sure you see the picture IT HAS TO BE BACKWARDS!!! after thats set start up your dremel and etch away. if you need tips on etching search it on this website you'll probably find something.
19 comments
Apr 2, 2009. 4:39 AMcyberpageman says:
Beautiful work! What sort of light do you use? You say, "a neon for a pc or car light," but I've never seen lights like that that are long and thin. Where can I find some?
Apr 2, 2009. 3:16 PMcyberpageman says:
Thank you. I appreciate your complete and quick reply.
Jul 15, 2008. 9:34 PMequinox55 says:
What is the pvc piping for
Sep 16, 2008. 8:14 PMKarnivore says:
Would it help to put something shiny like Aluminum foil on the inside of the PVC, then seal the ends (but make a few holes for power)? -Karnivore
Sep 19, 2008. 1:38 PMKarnivore says:
Quite welcome! I can just think of all kinds of uses for this...
May 30, 2008. 7:31 AMGreenehouse says:
Another way to "etch" this would be to cover the plexiglass with a plastic film, put your logo on the film and use an exacto knife to cut your logo out of the film. Then you just use an etching paste you can get at any good craft/hobby store to etch the plexiglass along the logo lines. After etching rinse and remove the plastic film and you should be good to go.
Jul 3, 2008. 4:58 PMcodongolev says:
or sandblast it. but maybe that only works with actual glass. my mom did it once for a cabinet door.
May 25, 2008. 1:12 PMvanpaun says:
I've seen this instuctable a few times, and I just got the joke! Open suse FTW
May 24, 2008. 8:20 PMxboxteen01 says:
awesome idea. and the slot/holder/dock thing looks sweet. use 4 of those and make a cool mirror or piccture frame. awesome job +1 vote
May 22, 2008. 4:15 PMNeonLime says:
This Is Pretty Cool! I Looked At Your Other Instructable Too! The Only Thing Is; Would anything Other Than A Dremel Work? >_> Mine Broke :D
May 23, 2008. 11:49 AMBig Bwana says:
Looks great.. Good bye Gates.. Any Router would work as well, in fact I find it easer to move and control then a dremel tool and I make less mistakes, it also cuts to a uniform depth as well (( Plunge Router works the best )) ... And a little tip if using a router, cover the sheet with packing or other clear tape and cut right threw it so you don't scratch the plastic sheet while working on it and peel it off as soon as your done , this is assuming it doesn't already have the protective coating still on it....
May 22, 2008. 4:22 PMLinuxH4x0r says:
Great job, really like this idea. Try using a drill press
Jun 17, 2009. 6:57 PMSpeedmite says:
Drill presses make holes. Not etch.
Jun 24, 2009. 12:42 PMGinger Magnus says:
A drill press would work if you used an endmill.
Jul 17, 2009. 8:34 AMSpeedmite says:
true....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
66
Author:slimguy379
