3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
extendo hand
extendo hand
Sometimes wish I had an extendo hand to help me reach things that are just a little too far away. For instance, picking plums off of the trees around here in Santa Clara, they are usually just about 12 inches too far away for me.
This is totally ridiculous, I know, but here it is...
here's my boyfriend Greg picking plums with it:
Step 1Stuff you need
stuff you need
a wrist brace (you can find these at Safeway made by Ace bandages)
5 spring type door stoppers
some wood and some screws
5 large washers with holes big enough to fit your fingers through
some string
some eyelet screws to guide the string through
cable ties
59 comments
1-40 of 59next »
Aug 12, 2009. 5:47 AMTBolt says:
I will post some pictures soon, I made one that didnt quite work but I have a great Idea to modify it a little bit from your design.
Aug 11, 2009. 1:32 PMTBolt says:
Im making one righ now!
Dec 3, 2008. 5:01 PMCarliPierce says:
I like these videos they are really fun, makes me want one too.
Nov 25, 2008. 8:59 AMpls says:
Awesome!, it grabs just like a real hand :D! wraps around the item.
Oct 9, 2008. 8:21 PMHardTymes says:
Now I can go dumpster-Diving in style! At least it won't cost me $29.95! Thanx! I'd sure as hell like to try it out! Hard Tymes
Aug 27, 2008. 5:09 PMNimphious says:
In your next version or possibly as a revision to this version, if you plan to do either, you could add a simple pulley to the base to make the grip stronger with less effort required by the user. Since it's such a long base many pulleys could be used, although after two it might be a little ridiculous since you'd need your other arm to pull the strings far enough to fully contract the fingers. Your design is great, and the only thing I would do differently following this instructable, would be adding a string for the thumb, and some more wood at the base to allow your thumb to control it separately from the hands, allowing you to do things like shake hands and operate buttons.
Jun 30, 2008. 1:10 PMbaconfish says:
Neato! I've been sort of planning on doing something like this myself (probably with a slightly larger model of my own hand), but with actual joints on each of the fingers + thumb. It'll be really complicated, but I'm thinking of using a system similar to the cables on bicycle brakes for flexing.
Aug 23, 2008. 9:42 PMhellstudios says:
you should look up adam's bionic hand from myth busters..... you might find that interesting....
Aug 24, 2008. 10:29 AMbaconfish says:
Would you happen to have a Youtube link, by chance? I can't find anything, but given that it's Mythbusters I'm guessing that it's just a *bit* more expensive than I could reasonably afford :P
Jul 21, 2008. 2:03 AMminerug says:
OSH? Isn't that Occupational Saftey Hazard? (Im not being stupid, it's a serious question)
Aug 27, 2008. 4:57 PMNimphious says:
I think you're referring to OHS, Occupational Health and Safety, I don't think the hazards have an acronym, although yours is reasonable enough.
Aug 28, 2008. 2:13 AMminerug says:
The reason I said OSH is because that's what the helth and saftey thingy-ma-bob of the government is called where I'm from (I could be confused though)
Jul 21, 2008. 7:23 PMminerug says:
Np
Jun 24, 2008. 10:09 PMDa_Fudge says:
all of the video's say "we're sorry, this video is no longer available". Plz fix! I might try this.
Aug 23, 2008. 9:44 PMhellstudios says:
that usually happens when your ping from your internet is to high, seeing as how if your running in mozilla it has sef timers for each page, if it takes longer than 20 seconds or so, it times the connection out and it doesn't display the page.
Jul 15, 2008. 2:25 PMdontwealllovebuda92 says:
I have a mac its working perfectly!!!!
Jun 27, 2008. 6:48 PMskimboarder33 says:
go vista!!
Jun 28, 2008. 4:14 PMDa_Fudge says:
I got vista too!!!
Jun 28, 2008. 6:14 PMDELETED_craz meanman says:
(removed by author or community request)
Aug 28, 2008. 2:15 AMminerug says:
I'll spoil the mood by saying 'stick to XP'
Jun 28, 2008. 11:23 PMgingernutsjonny says:
yeah vista
Jun 28, 2008. 8:22 PMemuman4evr says:
lol vista fire fox ftw!
Jun 26, 2008. 3:05 PMDa_Fudge says:
I dunno.
Jun 27, 2008. 3:31 PMDa_Fudge says:
its O.K. got it working.
Aug 22, 2008. 3:14 AMC14ROCK1710042 says:
PINOY KA BA??
Jun 24, 2008. 11:15 PMdarkmuskrat says:
Thats ingenious to use doorstops as fingers :P (I would probably just pull them and make that spring sound though :)
Jun 25, 2008. 5:27 AMfkuk says:
the fingers look flimsy when you picked up the rose you didnt realy pick it up you managed to close the fingers and lift it up and the indext finger is bent
Jun 30, 2008. 12:02 PMehmbee says:
You can use bicycle or motorcycle chain as "fingers"-just MIG weld some "bones" every few links and let your "joints" bend freely to make the closest to real fingers you can get at home in your shop. Then you can spring load them to return to the open position. Or reverse the process so they close automatically. If you can't weld try JB weld or something-look for the old Mythbusters episodes-they've made robot hands for busting myths once or twice this way with motorcycle chain and they are SOLID.
Jun 30, 2008. 12:52 PMsanty22 says:
Holey youtubes batman!
Jun 28, 2008. 11:36 AMEnigmaMax says:
you should try to make this colapsable.
Jun 29, 2008. 10:54 PMpiper1234 says:
maybe impractical but one step to the next generation improved ; )
Jun 29, 2008. 3:17 PMhandyScrapper says:
good idea, but to be honest, its totally impractical in a number of ways.
1-40 of 59next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
92
Author:RaisedByRobots
clueless enthusiast
