3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
eyeRobot - The Robotic White Cane
Abstract:
Using the iRobot Roomba Create, I have prototyped a device called eyeRobot. It will guide blind and visually impaired users through cluttered and populated environments by using the Roomba as a base to marry the simplicity of the traditional white cane with the instincts of a seeing-eye dog. The user indicates his/her desired motion by intuitively pushing on and twisting the handle. The robot takes this information and finds a clear path down a hallway or across a room, using sonar to steer the user in a suitable direction around static and dynamic obstacles. The user then follows behind the robot as it guides the user in the desired direction by the noticeable force felt through the handle. This robotic option requires little training: push to go, pull to stop, twist to turn. The foresight the rangefinders provide is similar to a seeing eye dog, and is a considerable advantage over the constant trial and error that marks the use of the white cane. Yet eyeRobot still provides a much cheaper alternative than guide dogs, which cost over $12,000 and are useful for only 5 years, while the prototype was built for well under $400. It is also a relatively simple machine, requiring a few inexpensive sensors, various potentiometers, some hardware, and of course, a Roomba Create.
Step 1Video Demonstration
Video Demonstration
44 comments
1-40 of 44next »
Jun 1, 2011. 12:39 PMmodmadmike says:
To all those who think that it will be completely useless because of stairs/bad terrain/etc, this is a prototype, and the final version can easily be made to conquer stairs by being built without the iRobot, and instead using motorized wheels therefore needing to be simply moved by the user like a regular cane. Or it can be built to use audio feedback instead of force therefore dropping the need for wheels entirely.
May 31, 2011. 11:40 AMjjaydam says:
Great Job
May 22, 2011. 11:08 AMtjosephcarter says:
I don’t really see how this present design can navigate things like stairs (or even curbs), something that would be an absolute necessity. Also, you’re going to have to think about terrain that a Roomba cannot traverse. That’s important because we must walk through mud, gravel, snow, etc.
It seems to me that you are approaching this with the notion that a person using a cane must bumble along in the hopes of finding a clear path, whereas a service animal sees and thinks about an obstruction-free route from origin to destination. With respect, that’s sighted-people-thinking. We blind folks don’t do that, and in fact we don’t want to do that.
I’ll do my best to explain why.
A cane user moves from origin to destination mainly by moving in straight lines, going from landmark to landmark (or static obstacle to static obstacle, in your way of thinking). Static obstacles that are familiar to us help us know where we are in relation to the world around us. Static obstacles that we do not know serve as waypoints to get back to wherever we were before we decided to go wherever we are going. We will tend to take the same route between two places until we become more familiar with an area to reduce the number of surprises.
When you encounter a dynamic obstacle with a cane (ie, a person or other thing that won’t be there later), you simply go around it and continue on your way.
Working with service animals is a little different. The dog will tend to take you around all obstacles automatically, unless you slow down and approach an obstacle to identify it. It’s a little different in appearance to an uninitiated sighted observer, but the navigation by waypoints is fundamentally the same. It’s just that the cane user will "run right into something" (that is, find it with their cane, often intentionally) before going around or whatever is necessary, whereas the dog will indicate to the user the presence of something in the path by leading the user around it.
The person using the cane or dog must still know how to find their way from place to place, cross streets, recognize and navigate hazards, etc. The dog doesn’t "see for you" in any real sense. But most dog users do walk faster than most cane users. Personally, I prefer the cane, but I'm not an animal person. The reason nobody has managed to replace the $35 cane with high-tech solutions yet is that the high-tech solutions don’t work everywhere a basic cane or a well-trained dog will. Doesn’t mean it can’t be done, just that the people trying thus far have not been thinking about how many environments blind people traverse and what exactly they expect the replacement to do for them.
And um, for those wondering, I’ve been using talking computers since 1982. My first was an Apple ][e with an Echo synthesizer. In the past 30 years, we’ve managed a FEW advances in the state of the art. ;) Undescribed images are a problem for those with little/no residual vision, and CAPTCHAs are just annoying, but otherwise we can usually manage.
Aug 3, 2010. 10:30 PMValleyWolf says:
I'm a blind guidedog user, and I think this is definitely the next generation of service animals. The only true flaw I can think of however, are the personality and expressions which come with the living animal. I was thinking to compact the size that one could construct the electronics(sensors, batteries, etc.) up the length of the cane, leaving the motors and, perhaps narrower and taller, wheels at the base/point. I believe there are many versions of this project worldwide, so good luck in that race.
Oct 3, 2010. 3:39 AMHiyadudez says:
Did you just say you are blind?
Oct 3, 2010. 1:04 PMValleyWolf says:
Yes I am blind, although I said it two months ago. Wy?
Oct 3, 2010. 2:58 PMHiyadudez says:
How do you type or know what I've typed then?
May 16, 2011. 12:48 PMGENERALCHAOS says:
BUMP keyboard and bump screen to read
Mar 17, 2011. 9:48 AMaseaheru says:
JAWS!
Oct 23, 2010. 7:41 PMdombeef says:
And the pictures?
Mar 12, 2011. 6:51 PMaseaheru says:
magnafacation
Mar 12, 2011. 7:39 PMdombeef says:
But their blind, they can't see at all
ok....... i know that, however, many leagaly blind people i know can see, but faintly and can only make out things close to them.....
Oct 4, 2010. 9:36 AMaseaheru says:
i have a friend ho is mostly blind, he an see a little, he and his wife use jawz, i know because my dad has to fix it about once a month
Mar 7, 2011. 3:46 AMAshurii says:
I believe that is a little bit of a strange statement "how do you know what I typed".
Many people with a significant visual impairment have some degree of residual vision. Hence to be blind doesn't mean pitch darkness. It often means a slight amount of vision remaining that is not enough to function.
Hence the visually impaired can use things like magnifiers, screen readers (It reads out the text on screen), self voicing for typing (Windows 7 is using this).
I love ressurecting threads for justice!
this was on xp, before vista even.............
Jan 23, 2011. 7:26 PMelbeil says:
Having a visually impaired daughter, I can strongly encourage you to continue to work on developing a consumer friendly product. Any input I can add from the standpoint of the visually impaired will be gladly given.
Dec 4, 2010. 7:44 AMaeray says:
A great Kickstarter project for sure. Keep it up.
Mar 5, 2010. 4:44 PMeyerobot says:
Needless to say, I love the name!
I have been working on a handheld device, That gives audio feedback according to distance, And when its done I may actually be able to fit it in old television remotes.
Of course its not as elaborate as this project, And requires people to train themselves to recognize what the sounds mean, But at least there are some guinea pigs(neighbors) close by, That are visually impaired.
But I really like this idea, Good job.
Feb 2, 2009. 8:12 AMGhost Wolf says:
what about crossing the sidewalk?
Dec 7, 2008. 5:57 AMinventer dude says:
thats a really neat idea, and it could be really useful and could help alot of people..... KEEP ON TRUKIN
Mar 7, 2008. 5:33 PMhomebowyerboy says:
Personally i believe that for that single purpose, yes, it might be better than a seeing eye dog. But, let us assume that this blind person is natvigating New York City for a few examples of why this might not be quite as good. Seeing eye dogs are trained to keep their owners safe, not just from tripping, but from walking into a street and getting run over, etc. Dogs also have an acute sense of distress, as in, they know when something is wrong. I've heard countless stories of regular dogs saving their owners from fires, finding help for someone having a heart attack, saving drowning people, etc. Speaking of water... that doesn't quite look waterproof, so if it's raining, your screwed. Again with the New york theme, someone walking around with that is probably 100 times or more likely to be mugged than someone with a dog, and they lose the protection provided by a dog. It's a good effort, but i think if i go blind, i'll stick with the dog.
Aug 28, 2008. 3:40 AMslowslow325 says:
Waterproofing isn't really a problem. I can usually waterproof a robot in a few minutes to a few hours. I also am afraid of dogs so I would rather use this than a dog especially if I was blind.
Dec 7, 2007. 5:40 AMsedition says:
Awesome Instructable. Great seeing that you were testing it in a way that would be indicative of it's use, i.e. blind-fold. So many great ideas are hampered (or problems even compounded) when those without disabilities try to assist those with. I'm taking the same approach with the Linux distro I'm throwing together and I'm amazed at how frustrating it can be when you run into a problem that is easily solved with raising that blind-fold. Unfortunately, those pit-falls aren't overcome by the people you are developing for, but at least you can account for and come up with solutions to those issues before your users run into them... Next step(s) getting rid of the Create? Could you not just use the Arduino as the brains and just attach your own motors, power source, etc.? It would reduce the weight, cost, etc.
Jun 21, 2008. 12:18 AMteamcoltra says:
Whats your linux distro for?
Jun 7, 2008. 10:48 AMA good name says:
It's a seeing eye dog and a cane.... I saw this in a magazine called robot... pretty cool.
Mar 14, 2008. 12:57 PMgrayecastle says:
what is it???
Dec 18, 2007. 11:48 AMjuliofo says:
Unbeliable good idea and a very good job! certainly a plus plus Congratulations from spain. Keep going. Saludos
Sep 15, 2007. 6:48 PMstatic says:
I as well wondered about stairs and steps. Can it be programmed to remember routes? I believe the blind count their steps from on point to another to know when they have to make a turn down another hallway or doorway. Have you yet approached your cane using fellow students to get their input product evaluation? I applaud your effort, but it's nearly impossible for an abled bodied person to perceive the needs of disabled. The disabled need people with your initiative, keep it up and involved the disabled one on one as well if you haven't yet. We can all learn from each other.
Sep 14, 2007. 12:38 PMAMalePoet says:
Good ground work. I too see potential in this. When the handle is dropped a deadmans switch? Much of the tech stuff is beyond me with out actually seeing it in front of me. My input is more practicle ergonomic fare. A cane is a round stick so is a one for the blind. The stick used looks like a street hockey stick. Perhaps a graphite tent pole with shock coarding inside to aid in portability. Also a smaller gauge stick would fit a brouder range of users. In future versions consider designes that may want to tollerate moisture or at least avoid deep puddles. Larger wheels would also make irregular terain easier to navigate.
Sep 13, 2007. 11:25 PMSuperTails says:
That's a wonderful idea but how would you know if you're home or in a place you want to be in. The advantage of a seeing eye dog is that a dog barks to let you know if your home. It also lets you know by stopping whens theirs traffic. All ideas have to start somewhere and this is a great start but it should be have some extra features on it before it becomes a seeing eye dog substitute. I would hate to be a blind person getting hit by on coming cars because I didn't know when to start walking or where the other side of the street is. Anyway this is a great start and good job.
Sep 8, 2007. 6:47 PMMatthew Oelke says:
This is a great idea, but i have a few questions. I have worked with sonar and I have also read many papers on them. I have noticed that sonar sensors sometimes give different readings based on density, i.e. a foam or soft substance that will absorb sound often gives a false reading to the point that some really porous, low density objects are all but invisible to the sonar. That brings me to the real question here, have you encountered any such sonar problems, and if so how are you combating them. The second question that I have is more of a curiosity. It looks like you don't have any forward facing blind spots, but how does backing up/turning around work, if at all? Thirdly, If I read this correctly, you just take the readings from all of the sonar at once and then calculate a vector that aims towards the middle. If that is the case, what happens when the eyerobot is directed into a narrow dead end? Thanks, once again this is a great idea!
Sep 9, 2007. 12:22 PMBrandon121233 says:
Sonar has come a long way, especially with the MAX EV1 (the same sonar module I use on my robot Walbot http://www.instructables.com/id/EXDGV5CF36FEUOP/?ALLSTEPS) and although it might get 1 or 2 bad readings when ranging a soft material, remember that it is taking about 20 readings a second. When you smooth out the data with averaging, it almost never gets a false reading regardless of the material. If you haven't tried a SONAR ranger like the MAX EZ1, if you ever do a project that requires ranging information, I would suggest that you try it out.
Sep 8, 2007. 10:25 AMi make shooting things says:
wow this has huge practical uses, in hospitals and around the home. If only it could go up and down stairs it would be perfect.
Sep 8, 2007. 7:40 PMtrebuchet03 says:
In Broward county, Florida (I think it's Broward General Hospital) - they used to have two blood/specimine transporting robots. They would deliver samples, etc. to different labs on different floors. It would push the correct button on the elevator to get to where it needed to go.
I remember that some of the people that worked there (including doctors) tried to get it to crash into them....
You said hospital - it reminded me of that.... You read it - you can't unread it :p
Sep 9, 2007. 8:19 AMGrimling says:
ROFL "You said hospital - it reminded me of that.... You read it - you can't unread it :p" To be honest , i was having that same conversation a second before i readed your last sentence .
Sep 9, 2007. 7:33 AMi make shooting things says:
isnt it amazing how far wev come, and it all started rocks/sticks held together with string, and of course fire the greatest tool of all. it used to take forever to make a fire, using a firebow now all you have to do is "flick your bic"
Sep 8, 2007. 4:17 PMmarc92 says:
Excellent robot and a great idea. I predict that this robot will win the competition. It is great that you would create this to benefit the blind community. This robot has huge potentials. i was wondering what inspired you to make this robot. do you know someone who is blind?
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:shrimpy
