3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
eyeRobot - The Robotic White Cane
Step 10Construction and Code
A few extraneous words on construction:
The deck of made by a piece of acrylic cut in a circle with an opening at the back to allow for electronics access, and is then screwed into the mounting holes beside the cargo bay. The prototyping board is screwed into the screw hole at the bottom the bay. The Zbasic is mounted with an L bracket's with the same screws as the deck. Each sonar is screwed into a piece of acrylic, which is in turn attached to a L bracket attached to the deck (the L brackets are bent back 10 degrees to give a better view). The track for the linear sensor is screwed right into the deck and the slide pot is mounted with L brackets beside it. A more technical description of the construction of the linear sensor and control rod can be found in step 4.
Code:
I have attached the full version of the robots code. Over the course of an hour I have attempted to clean it up from the three or four generations of code that were in the file, it should be easy enough to follow now. If you have the ZBasic IDE it should be easy to view, if not use notepad starting with the file main.bas and going through the other .bas files.
1 comment
Jan 23, 2011. 7:26 PMelbeil says:
Having a visually impaired daughter, I can strongly encourage you to continue to work on developing a consumer friendly product. Any input I can add from the standpoint of the visually impaired will be gladly given.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:shrimpy
