Fake 'ERROR' Trick
Published
Introduction: Fake 'ERROR' Trick
Now before i start there is some people that made an instructable about the same trick but they just didnt explain it well...so i'll be making an ERROR trick so you can fool anyone you want
before i start i want to point out that i made this trick using WINDOWS 7 so i dont know if it will work on WINDOWS XP
Step 1: Any Kind of ERROR You Want...
this trick is actually a simple NOTEPAD that you write in it a code [i will give the code in the next step] then save the notepad as a .VBS file and open the file and it will look like an actual error
Step 2: The 'CODE'...
ok as i said...i tried this in windows 7 i dont know if it would work on windows XP but give it a try it might work
Now open the notepad and write:
dim answer
answer=MsgBox("HERE YOU WILL WRITE THE ERROR",36,"HERE YOU WILL WRITE THE ERROR NAME")
NOTE: if you just copy it and paste it in the notepad it would be easier
Step 3: After the 'CODE'
when you wrote/copied the code save the notepad as .VBS  file
for example-       FAKE ERROR.VBS
and now when you open the .VBS file the fake error you made will come up and SCARE the reader
Step 4: THE END...
i hope you understood it more than the other instructables and if you liked it plz do the following:
rate
comment
subscribe
check out my other instructables.
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    4 Comments
    How do you persuade people to open the .vbs file without thinking it's some kind of prank?
    L
    You can change "target file" in desktop shortcuts, so it would appear to be more original.
    THE BEST COMPUTER PRANK EVER!!!!!!!!!
    tell them that its a new program for them to open
