Fantasy Warrior From a Cow Bone Hip
390
Posted
Introduction: Fantasy Warrior From a Cow Bone Hip
How I made a cow hip bone into a warrior glowing mask
Step 1: How Its Made
Materials
Base
Spray paint- Rusto-oleumSilver
Small paint brush
Acrylic black pain
Hot glue gun
Glass nippers/cutter
Glass mosaics- 50 squares of black and about 20 mirror pieces Feathers- white, black and brown White fur- found a jacket at a thrift store
Glowing orb
Battery powered Led Christmas lights- Blue
Perfume top- For the glowing crystal
Insta morph- mold able plastic www.instamorph.com
Horns
Drywall Plaster
Drywall mesh- Perma mesh
Needle nose pliers
Electrical tape- black
Popsicle Sticks
Door rubber insulation 2 pieces
Wire cutter
wire close hanger
Base
I sprayed painted the entire cow hip all silver. I sprayed painted all the interior cavities making sure everything was covered. Once dry I painted the lower part black to the area I wanted the black mosaics to sit. After the paint dried I then applied the mosaics with my hot glue gun. I had to use my glass cutter on a few to score and use my nippers to get the shape where some of the Cow hip was curved. I use the mirror pieces around the eye and nose.
Horns
Cut the length you want your horns to be. Take door insulation and run your wire inside of them so you can bend them to the shape you want Lay your 2 pieces side by side to make sure they are bent exactly the same I bent the bottoms flat so I could easily fit them into the cow cavities about 1 inch. Now wrap the horns with the Drywall mesh. It has a sticky adhesive back to it so no need to worry about it slipping. Once you decided the thickness apply the drywall plaster and let it fully dry about a day. I used Popsicle Sticks to apply it and a paint brush to keep in smooth. Then just start wrapping the black electrical tape until all drywall is covered. I then took them and positioned them in the mask. I used coat hangers to hold them in place and secured it with the black electrical tape. I then glued the feathers and fur with my hot glue gun around the horns and top part of the mask.
Glowing ord
I found an old perfume bottle and used that for the crystal part. I then the Christmas light and molded them together with my instamorph. I used about two table spoons of the instamorph and place them in a coffee mug and melted them for 2 or 3 minutes. Then rolled in around the Christmas lights so they could all fit into the perfume top. Then took an old Christmas silver ornament and stuffed the remaining wire inside so they weren't showing. I then melted some more instamorph to secure it on my the front so it would reflect off the mirror piece I made for the nose.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
