Instead, this version uses Dollar Store supplies and faux foliage to create an economical, wearable, faux flower planter necklace.
Follow along and make your own version. Men, this is a perfect for that lady in your life. And ladies, make your own and show off your crafty-awesomeness. Either way, this cheap floral project is sure to turn some heads.
Enough talk, let's make a planter necklace!
Remove these ads by
Signing UpStep 1Tools + materials
tools:
materials:
I will have to put it on my projects-to-be-made list :)
Yes, the planter will sit correctly when worn, but care needs to be taken when positioning the chain location in regards to the thimble. Step 3 states "Take care to notice the position of your chain while the glue is setting, hold the slack of the chain above the rim of the thimble to ensure that the thimble will hang correctly when the necklace is worn."
This step is directed towards planter placement when worn, proper planning and cuts into the thimble will keep your planter upright at all times. If in doubt, make sure that there is a weight in the bottom of the thimble, like a small nut or washer to add extra weight, or cut a smaller vertical slit for the planter to rest in. This will allow your planter to naturally hang with the bottom always down.
