3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
felt beads TUtorial
felt beads TUtorial
Queres hacer bolitas de fieltro?
Do you like felt beads?
Step 1Felt beads
felt beads
Dip your dry pompom in water and add some dishsoap...
Sumerje el ponpon en agua, o mójalo con agua y una gota de detergente.
Then strat to rolling it between your palms... roll gently, no pressure until the core is firm, rolling in different directions so all surfaces get equal time felting. Once a nice round ball is forming slowly add more pressure.
Después empieza a moldearlo entre tus manos, suavemente, girando la bolita entre ellas, sin mucha presión inicialmente, hacia todos lados para que quede enfieltrada pareja. Después que ya tiene la forma tu puedes ejercer más presión y darle el tamaño que deseas.
And it's ready!.. you have to wash the ball and then you can use or dye it.
Y listo! lavas la bolita para sacar el detergente y la puedes teñir o lo que quieras...
9 comments
Jan 12, 2008. 1:13 AMQuadro313 says:
Could we do this by getting some wool threads and cutting them down to little flakes?
Mar 1, 2010. 1:19 PMvivabear says:
I don think you have to cut them into flakes. you simply just need to make the "fur ball" then do the rest.
I discovered this after I accidentally machine washed my hat with a fur ball on top and it turn into a little felt ball. I just have to give it to my cat to play = =
May 13, 2009. 5:55 PMFeltyfriend says:
I love using these to embellish things www.feltandcraft.com has like 100 roving colors too so the possibilities are endless!
Apr 11, 2008. 10:57 AMivoncita says:
Hola : Me encantò que estè en español!!! me puedes decir como es el material que usas?
Jun 7, 2007. 3:07 PMMica says:
Disculpame verrito pero esta pesimamente explicado. no se entiende nada de nada! Estaria bueno que lo expliques mejor o la hagas de vuelta. me interesa mucho aprender
Dec 1, 2006. 6:02 PMTool Using Animal says:
But I will ask a relevant question, what is the material you start with? The other one calls it "wool fleece", but what's that? I got an idea....
Dec 1, 2006. 9:00 PMtheRIAA says:
"TUtorial" LOLo
Dec 1, 2006. 7:24 PMrimar2000 says:
Muy bueno. ¡Y bilingüe! Nunca creí que fueran tan fáciles de hacer. (Very good. And bilingual! I never thought that they were so easy to do.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Verrito
