Introduction: Fertiliser Dosing Pump for Aquarium
In heavily planted aquarium with high light and CO2 addition, on almost daily basis I have to add liquid fertilisers.
Problem appears when I'm going on holiday (or want to sleep bit longer and there's no time in the morning to put some fertiliser before work ;-) ).
The off-shelf solutions are quite expensive, so I've decided to give a go peristaltic pump.
The choice I've made because peristaltic pump is probably the most accurate way for dosing liquids.
Step 1: Parts and Tools
I've bought used peristaltic pump from ebay. Its actually pump itself, gearbox 1:150 and DC electric 12V motor.
I also purchased electronic timer with the weekly schedule exact to 1 minute.
Airline enough to reach aquarium, and another small piece from pump to bottle
Rest of the bits and pieces I found at work/home:
There was 12V power supply from dead old netgear ethernet hub, and small pads/skid protectors again from the old hub
Small piece of aluminium angle bar
Piece of 5 mm plastic ~8x13cm
Pentium 4 air duct from ATX case ;-)
Bottle which fit inside air duct
Screws, nuts and washers
Step 2: Assembly
Basically nothing to say about. Put everything together (as shown on the photos) and keep it as tidy as possible, avoid sharp edges (sand all sharp edges). Make counter bore to hide screw heads, etc...
Step 3: Adding to Setup
At first of all you need to figure out the flow rate. Grab some watch and measure flow over one minute. You can use syringe to measure amount of water, or whatever you know volume or scale (remember 1g water =1ml water)
My pump got quite convenient flow rate which is ~5ml/minute.
If you have ready fertiliser (bought from a shop for example) and the rate didn't fit to one minutes, you might recalculate and mix fertiliser with demineralised water.
For example: you peristaltic pump got flow rate 7ml/min you want to add 5ml of fertiliser at once, and you have 200ml of the fertiliser, the math is:
7/5=X/200ml => X=7/5*200ml => X=280ml that's volume of the fertiliser mix. Now 280-200=80ml you have to mix 80ml of water with fertiliser, to get right amount of nutrients in one minute.
If you making your own fertiliser just simply recalculate you mixture, and add right amounts of powders to water. (but if you're enough experienced to make your own PMDD I don't need to explain anything)
Useful links:
http://www.theplantedtank.co.uk/PMDD.htm
http://www.theplantedtank.co.uk/calculator.htm
Now timer, I've setup mine about 20 minutes before lights on, but depends on preferences. Again, on the internet you can find plenty of tutorials how and when dosing.
I've sicked the other end of the tube (outlet) to canister filter outlet just above the water surface so water is mixing instantly with the drops of fertiliser.
Final step is deaerating tube. Just run the pump for a while and see when liquid will reach the end of the tube, that's all.
Good luck.
Step 4: Thoughts
The electric motor (or gearbox need to figure out) is quite noisy, so I need to make sort of enclosure for pump itself. Quick-and-ugly solution might be a piece of foam.
It's good idea to separate micro and macro nutrients (two solutions, two pumps), but in my opinion for my 70L aquarium its overcomplicated. So I keep separate micro and macro and mix it together on weekly portions. Again google is your friend ;-).
The price for whole setup was 1/3 of the branded available in the shops, so in my opinion worth to try.
Regards
the white
