Filterized Dog Water Bowl
6,875
4
13
Posted
Introduction: Filterized Dog Water Bowl
welcome! this may be dumb but this is my first invention. i was 10 yrs old old when i made this, now im 11. also it is missing a bubble stone but i could not go to walmart with my mom :(
Step 1: Materials
this is what you need:
1. fish tank air pump
2. glass of water
3.styrophone bowl
4. 5 inch tube (ice maker tubing)
5.a pen.
here is a image of the items
Step 2: Instructions
here is a stupid >:-( video on how to make it. also there is manual instructions too. oops i cant upload a video >:-(
Step 3: Step1
make a incision in the bowl with the pen.
Step 4: Step2
feed tubing through hole
Step 5: Step 6
connect the tube to fish pump.
Step 6: Step6
attach bubble stone i don't have a pic so i can't show you <:-(
Step 7: Step7
add water!
Step 8: FINISHED
present your gift to your pet cat,dog,hamster,or parakeet.
Step 9: A LITTLE DEMINSTRATION FROM ODIE
my dog Odie loves it!!!!! finally here, the video!!!!!
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    15 Comments
    Actually, I think you are on the right track for a filter. If you have a fish tank air pump, you must have a fish tank. Now, remembering that you pump air down to the tank filter in order to pump water up through the filter . . . You will need: 2 bowls (plastic) that will fit (stacked) in your water bowl; 1 2-3 inch piece of 1/2" pvc pipe; some kind of filter material (3M nylon scrubbing pad maybe); and your pump and air tubing. Cut the bottom bowl down to about 1 to 1-1/2" high. You want water from the water bowl to come up over the top, down through the filter, and up the pipe to the top bowl. Drill holes at or near one end of the pvc pipe (1 must fit your air tubing, the rest don't matter, they just let in water. Fasten that end to the inside of the bottom bowl. Fix the air tube in its hole at the bottom of the pipe. Fill the bottom bowl around the pipe with filter material. Cut/drill a hole through the bottom of the top bowl and fasten it (upright) to the top of the pipe. Place it all in the dog's water bowl, and fill the bowl with water. Hook the air tube to the pump and turn it on. The air coming up through the pipe should carry water along with it up to the top bowl, where it should spill over the side. (You want to be sure it is smaller in diameter than the main water bowl, or your mother will be most upset with you, and you can forger EVER going along to Wal-Mart) I want to thank you for prodding me along these lines. I have been trying to think of a way to get filtered water to my dogs without putting live wires in their dog bowl for a fountain pump. It's not what we don't know, but what we know that isn't so that gets us in the end. JLMowery
    Good work, OK the detail may be slightly wrong BUT It is a great idea to keep water tasting fresher for dogs or even cats even if not exactly filtered. Just change the name then the downers to good ideas will have to shut up!!!
    Go BOY!!!!keep inventing
    Not only may you one day make something No-one else has thought of, thus be able to make a fortune to keep your Mom but you are using your initiative, ingenuity, imagination and if you use recycled bits saving the planet at the same time.
    bubbling the water does not filter it, but i can see that the dog might like moving water better because it would not go stale as quickly. If you wanted to filter it you would have to make the pump pull water out of the bowl through a filter and back into the bowl.
    I'm 13 and I think this is really good. I've got a air pump in my garage so I'll try this because I'm on school holidays
    hello all you are doing is adding oxygen to the water it does not get filtered in any way so it is really pointless
    even if it was filtered, what's the point? They drink mud puddles/lick themselves...
    Only if your dog/s are kept out side on the loose....Which here its against the law!! Mine are inside dogs (2) and cats (16) and they all love filtered water...lol
    yea, because it's not like they try to clean themselves or anything... and there can be much more harmful chemicals in water, than on their body... And keep up the good work "get to da parakeet" don't be discouraged by others!
    Correction = it is adding air not just oxygen. so what was your point ? he is 10 and tried but you failed to add to this.
