3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
firewood boomerang
Step 5Shaping and varnishing
shaping and varnishing
SHAPING
the shaping is probably one of the easiest steps in building the boomerang .you need to make it look like an airplane wing .a tear drop on its side with a flat edge is a simple way to explain it without seeing a picture .use the spoke shaver to rough out your shape and further refine it using the micro plane and then the palm sander working down from 80 grit to 250
VARNISHING
this to is an easy step .once you have finished your shaping and done your final sanding with the 250 grit paper .you need to seal it so the wood doesn't discolor or warp from absorbing moisture in the air .what finish you decide to put on the boomerang .you should read the instructions and follow them .one trick i've learned about varnishing is that you want to put on a first coat .lightly sand and then do your final varnishing and you will have a perfect finish
2 comments
May 13, 2010. 4:44 AMskyhi1994 says:
will this thing actualy work?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:somebullcrap
