3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
fischertechnik Bicycle
Step 8Bottom Bracket and Cranks
Fix a Gear Wheel T30 near the center of a Clip Axle 45 with a Flat Hub Collet and a Hub Nut. Insert the assembly into the second Building Block 15 with Bore. Fix the gear in place by adding Cranks to each axle end. Add Bearing Sleeves on each crank for a smooth pedal action.
Note: The Cranks are oriented 180 degrees from each other.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:ftking_83702
