Introduction: Flashlight Survival Kit
A cheap and easy survival kit.
Step 1: What You Need
- money
- matches
- pain killers
- fever pills
- fishing line
- part
- of a paper clip
- cheap flashlight from amazon
- Canadian: http://www.amazon.ca/gp/product/B00SIVEOSM?psc=1&r...
- US: http://www.amazon.com/Zoomable-Cycling-Camping-Fla...
Step 2:
Extend the flashlight and twist while pulling the front of the flashlight to remove the body of the flashlight from the led. Then pry the circuit board off.
Step 3:
Trim the matches so they will fit inside the small cavity. Then put the pills, matches and anything else you want into the cavity.
Step 4:
push the circuit board back into the cavity
Step 5:
Reassemble the top then tape the paper clip bit onto the $5. Wrap the bill around the battery and wrap the fishing line around the bill. Put them into the flashlight and then reassemble the flash light. Check to see if the flashlight works and now your done.
Tools Contest
Apocalypse Preparedness Contest
